Injector Chart - Page 2 - Dodge Cummins Diesel Forum
94-98 Performance Tech articles dealing with gaining power from the 2nd gen 12V engine
post #13 of 60 (permalink) Old 09-18-2009, 05:32 AM Thread Starter
DTanklage's Avatar
stock 2nd gen inj - vary depending on model but all are 145° injectors
49 state 160 hp - 5x9 .000318
49 state 175 hp 5x9 .000318
180 hp 5x9.5 .000354
160 hp cpl 1863, (actually a 180) 5x9.5 .000354
all calif trucks '96-98 were 180 hp = 5x9.5 .000354
215 hp - 5x10.25 .01025 .000412
300's and 330's same size - 4x12 = .000452
370's - 5x12 = .000565 155° spray pattern
435's - 5x014 = .000769 avail in both 155 and 145° spray pattern
ddp stg III (90 hp) = 50 LPM (liter per minute) 155° 5 hole extrude hone inj <5x12 270 bar
ddp stg IV (140 hp) = 66 lpm - 5 holes smaller than .0135 270 bar
ddp stg 4plus - no longer avail now considered comp waiver must be signed to obtain
ddp comp = 73-90 lpm depending on application same for pop
all four start out as 155° marine nozzles and are extrude honed
the flow numbers (lpm) i posted is what was printed on boxes that i received from ddp
there are posts on other forums that vary slightly with these numbers
measured the holes myself (.0135 would not go in a stg 4 ect)
have not used 50 or 75 hp ddp inj - have no idea what size the holes are
custom injectors -
5x.012 = .000565
5x13 = .000663
5x14 = .000769
7x10 = .000549 (24v conv inj are usually 7 hole)
7x12 = .000794
6x13 = .000795
5x15 = .000882
6x14 = .000923
5x16 = .001005
6x15 = .001059
7x14 = .001077
5x17 = .001134
6x16 = .001206
5x18 = .001272
6x17 = .001360
5x19 = .001416
6x18 = .001526
5x20 = .001570
ind inj super dragon flows (10 hole) - 5x10.25 + 5x18 .001684
6x20 = .001884
5x22 = .001900
5x24 = .002261
6x22 = .002280
5x25 = .002459 (this is what some refer to as a true competition injector)
*i figured out the csa (cross sectional area) for ea injector. those numbers are in bold
if you want to figure 24v stuff or something that is not on the chart use rē x pi x # of holes
take the hole size divided by 2 times pi (3.14259) times the number of holes
DTanklage is offline
post #14 of 60 (permalink) Old 09-22-2009, 11:06 AM
NM12VALVE's Avatar
wow this is a great thread, the pensacola's(stage 2) i had were 6 hole, i have no idea what they were, i always assumed they were marine 300's but now i really dont know seeing that 300's are 4 hole... anyone with any ideas?
98 RAM2500 AUTO 4X4 12 VALVE!!!!!BHAF, FUEL PLATE AND AFC FORWARD, HOME GROUND 100, s300/s400 TWINS, A-METER BOOST PYRO AND TRANS, 5" INTO 6" MITRE CUT STACK, SILENCE RING GONE ATS CONVERTER AND BUILT TRANS KDP tabbed-timing 16 deg-3GSK, stage 2 injectors
NM12VALVE is offline
post #15 of 60 (permalink) Old 09-23-2009, 04:06 PM Thread Starter
DTanklage's Avatar
thanks, i added the csa for some more of the popular custom sizes
guess its not worthy of a sticky
no one needs to know what size their injectors are or how they compare to other injectors?
thanks again
post #16 of 60 (permalink) Old 09-23-2009, 04:23 PM Thread Starter
DTanklage's Avatar
think you could pm a mod and tell him so?
pensacola's(stage 2) are 4 hole...i dont know what you had
they are made in china
the entire injector
post #17 of 60 (permalink) Old 09-28-2009, 03:22 PM
98cummins4x4's Avatar
I had Pensacola Stg. 2's in one of my trucks. They may only retail for $214, but you GET WHAT YOU PAY FOR! They are awful injectors and I will never run another set. I wouldn't have bought them, but they were in the truck when I bought it.
BTW DTanklage, this is a fantastic thread with great info. I've been wondering about my 435's for ages.
This is very useful info and very easy to read, great job.
2012 3500 G56 Single Cab Dually it's smart, dark windows, A/C, usually yankin a gooseneck
01 2500 12V, NV5600, 66/74/14, 5x14s, Studs, O-Rings, Fluidampr, 3600DD 471HP/1298TQ
95 2500 NV4500 215 pump, 64/71/14, 370s, O-Rings, 3850DD 451HP/1159TQ
98cummins4x4 is offline
post #18 of 60 (permalink) Old 09-28-2009, 03:45 PM Thread Starter
DTanklage's Avatar
your welcome
plz pm a mod and request it be made a sticky
its info that i as a newbie was very curious about and a lot of research and time went into making this chart
we still need a piston chart with years and p/n's and the different bowl dimensions
the two go hand in hand ya know...
post #19 of 60 (permalink) Old 09-29-2009, 05:08 PM
xzaq103's Avatar
iTrader Score: 5 reviews
Nice write up Don!
xzaq103 is offline
post #20 of 60 (permalink) Old 09-29-2009, 11:00 PM Thread Starter
DTanklage's Avatar
thanks
and thanks to who ever stickied it
who is gonna make a turbo chart for the newbie???
"suber b what?"
lol
post #21 of 60 (permalink) Old 09-30-2009, 02:38 PM
tony597fitter's Avatar
Don,
DDP1s and 2s arent a marine nozzle, they are 145* truck nozzles.
Add that to the list.
97 ECLB 4x4, ,
UNDER CONSTRUCTION
tony597fitter is offline
post #22 of 60 (permalink) Old 09-30-2009, 10:58 PM
kjpcummins
Guest
Posts: n/a
don would you be able to figure out the csa for a 7x10 and 7x14 also
thanks kyle
post #23 of 60 (permalink) Old 10-01-2009, 12:27 AM Thread Starter
DTanklage's Avatar
thanks kyle
7x10 - .000549
7x14 - .001077
to figure csa of an injector i take the hole size divided by 2 times pi (3.14259) times the number of holes
a 7x10 has seven .010" holes
a 7x14 is bout twice as big ( ! ) thats why you have to look at csa
off topic but you should see what happens when you start increasing the size of a nitrous jet
The Following User Says Thank You to DTanklage For This Useful Post:
post #24 of 60 (permalink) Old 10-01-2009, 07:30 PM
kjpcummins
Guest
Posts: n/a
thanks i was just curious as im going to be running a 7x12 once the nozzles get sorted out and was curious how much bigger a 7x14 was cause i know they can easily fuel a 3.0 turbo with a ppump 24v and a 7x14 would be the next step if i ever got a larger turbo. You can do so much with a 7x10 injector i cant imagine the fueling you can do with a 7x14
