in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
94-98 Tech Articles
94-98 Performance
Follow Forum
Create Thread
UPDATE:
Images posted between 02/20/24 and 02/25/24 may not work, re-uploading the image by editing your post should fix this
More info found HERE
March's Cummins of the Month
is now open for entries!
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
Sticky
DV Side By Side Testing Writeup!
Home-Built 12valve
Nov 22, 2015
Locked
4
72
47K
Jun 11, 2020
by
Mechanick858
A
Sticky
Which do you adjust first... Star wheel or smoke screw?
Av3fire
Apr 24, 2013
Locked
7
8
9
166
185K
May 29, 2020
by
jserman35
Sticky
d89 Presents: How to Install a BHAF Without Completely Screwing it Up
dauntless89
Feb 21, 2016
Locked
29K
Apr 19, 2018
by
Jursick
Sticky
The AFC Live Resource Sticky
dauntless89
Oct 21, 2016
Locked
11
13K
Apr 13, 2017
by
AZ4x
Sticky
The Fuel System Resource Sticky
dauntless89
Oct 22, 2016
Locked
3
9K
Feb 2, 2017
by
dauntless89
Sticky
Delivery Valves
Big Blue24
May 24, 2013
Locked
3
4
5
93
137K
Oct 9, 2016
by
98whitelightnin
Sticky
Injector Breakdown
WShupe
Apr 21, 2015
8
11K
Apr 21, 2015
by
WShupe
D
Sticky
Running No Plate
Don Wagner
Mar 2, 2009
Locked
51K
Mar 12, 2009
by
Racer9
C
131, 191, 024 test stand comparison
Cummins35.9
Feb 9, 2010
11
20K
Oct 9, 2021
by
potthoff
Governor Spring Install w/ Pics!
12valveterror
Feb 27, 2010
14
141K
Dec 22, 2020
by
SubliminalME
afc tuning explained
OrangeP
Aug 25, 2010
77
241K
Apr 27, 2014
by
country_hick
T
Injectors Vs. Delivery Valves
Tyler Smoot
Oct 24, 2013
3
9K
Oct 24, 2013
by
ghostman
all afc star wheel and pre boost(smoke screw) waste gate answers
Hardymanracing
Dec 29, 2009
8
53K
Feb 12, 2010
by
Hardymanracing
D
Injector Chart
DTanklage
Sep 13, 2009
59
159K
Feb 10, 2010
by
DTanklage
D
turbo chart
DTanklage
Oct 7, 2009
128K
Jan 23, 2010
by
CATSTACKS
delivery valve install, with pics!
justadonor
Jul 16, 2009
1
46K
Jan 21, 2010
by
illflem
I
Modify Stock Airbox???
illflem
Jan 18, 2010
0
12K
Jan 18, 2010
by
illflem
D
timing the p-7100 (timing chart)
DTanklage
Oct 2, 2009
3
46K
Oct 2, 2009
by
DTanklage
Big Honking Air Filter part #'s
Racer9
Apr 5, 2009
0
33K
Apr 5, 2009
by
Racer9
Properly clearancing your rocker stands for ARP's
Motorsport Diesel
Oct 23, 2007
1
9K
Oct 24, 2007
by
farmboysdiesel
16cm turbine housing swap.
Racer9
May 6, 2007
0
14K
May 6, 2007
by
Racer9
Home Made Throttle Control/High Idle Set-up - NC
ndurbin
Feb 10, 2006
50K
Apr 11, 2007
by
ndurbin
T
Fuel Plate Profiles - NC
Tom05
Dec 30, 2005
98K
Mar 14, 2007
by
Rbratby
47RH Manual Torque Convertor Lock-up switch - NC
ndurbin
Dec 30, 2005
6
19K
Feb 6, 2007
by
ndurbin
G
P7100 Custom Plate Tuning - A
got...DIESEL?
Mar 5, 2006
15
49K
Jan 5, 2007
by
flubyux2
B
Easy AFC breakoff screw removal -A
Baja
Jun 13, 2006
13
29K
Oct 25, 2006
by
Greenleaf
T
Sleeved engines - NC
TimmyWilliams
Feb 1, 2006
6
15K
Feb 1, 2006
by
RustyJC
94-98 Performance
762
posts
1.8M
views
Tech articles dealing with gaining power from the 2nd gen 12V engine
Show Less
Join Community
Grow Your Business
Forum Staff
View All
Loki223
Administrator
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
94-98 Tech Articles
