Best streetable 4K springs? - Dodge Cummins Diesel Forum
 2Likes
post #1 of 17 (permalink) Old 01-11-2020, 01:28 AM Thread Starter
myother4x4isaCJ7's Avatar
The price on gov springs varies quite a bit, you can get “off brand” for as low as 40 bucks all the way to premium PDD at 250.... I’m looking for good street manners and idle quality. Sorry if it’s a newb question but I’m new to the p pump world. Before you tell me to use the search engine all I could find was the issues people have with pac-brake springs.
myother4x4isaCJ7 is online now
post #2 of 17 (permalink) Old 01-11-2020, 10:49 AM
gear_grinder's Avatar
pacbrake springs, done.
https://www.ebay.com/itm/PacBrake-Go...OtveFvMLq8LITw
1997 2500 2wd auto
1996 3500 4x4 auto
gear_grinder is offline
post #3 of 17 (permalink) Old 01-11-2020, 12:46 PM
Call Seth Farrell. Last I ordered from him the set was a little over 100. They were drop in. No machining required.
Sent from my LG-H932 using Tapatalk
56Cummins likes this.
hemirunner426 is offline
post #4 of 17 (permalink) Old 01-11-2020, 06:11 PM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
PDD Budget Builders for life. Installed a couple sets of springs and the budget builders just seem to always drop in and idle good. as opposed to others that needed some TLC. just my experience though, and I can't say I've installed every set out there.
Gandalf the Donkey Hauler - '96 2500 ECLB G56 SB-DD NP241CLD 3.54's, Firerings @ 160ftlb, PDD 4K GSK, PDD 5x18's @ 260, 025's, AFC Live, 28° Cogwheel, AFC Stop-Bolt, HO LP, TPP Manifold Blanket, P&P, Billet 56/64 HX35/GT45 W/Spring gate, EB, OBA, OBP, CC High Idle, BRA, Hotrod PS Pump, Str box brace, SuperSport Headlights, DIY GN Hitch, couple gauges. 733hp/1350tq at NWDC.
Shaughty - '95 2500 RCSB 2WD, PDD 850hp Trans, a lot less than 850hp.
Cowboy303 is offline
post #5 of 17 (permalink) Old 01-11-2020, 08:07 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Ive installed pac brake and DAP's brand. If you have an auto trans, I really dont think it matters. If Seth has a set for $100 you couldnt go wrong.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #6 of 17 (permalink) Old 01-12-2020, 12:26 AM Thread Starter
Sweet thanks ill probably use Seth farrel or pdd budget builder depending on who’s cheaper.
post #7 of 17 (permalink) Old 01-13-2020, 04:23 PM
Antonm's Avatar
I've only ever installed one set of governor springs, but they went off without a hitch. They installed fine, no weird or weak idle, they just work like they're suppose to. I suppose I just got lucky, but I got mine from a Canadian seller on amazon by the name of DieselTuff.
97 Extended cab 4x4, NV4500, gauges, valair single disc clutch, 4k gov springs, +60 lb valve springs, tool steel retainers & locks, homemade #10 plate, medium tension AFC spring & flat washers, 5x13 sac injectors, 055 DVs, stock turbo and manifold for now. Lifted on 37" tires and 4:10 gears.
Antonm is offline
post #8 of 17 (permalink) Old 01-13-2020, 05:01 PM
The Uppity 12v Guy
dauntless89's Avatar
PacBrake springs are terrible.
hemirunner426 likes this.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #9 of 17 (permalink) Old 01-14-2020, 09:29 AM
I can tell you 4k springs with a 5speed duel disk ,, can get ignorant .
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #10 of 17 (permalink) Old 01-14-2020, 12:07 PM Thread Starter
Why is that? Touchy throttle? You could try playing with the preload on the springs to see if you can tune it out. But mine is auto so won’t have those issues.
post #11 of 17 (permalink) Old 01-14-2020, 01:17 PM
True you will not in an auto.
In a manual the " solidness " of the driveline ( no slippy converter to dampen anything ) combined with the 4k springs touchy throttle , bumpy ride and rear spring wrap/un wrap can give the truck a " bucking boot scoot'n boogey " at times even driving normally ( im olden ) . Nothing one can do , but cease what you are doing and start over .
Just life with 4k springs , other mods and a manual. Not a huge deal .
post #12 of 17 (permalink) Old 01-14-2020, 01:23 PM
Antonm's Avatar
I'm curious what you mean by this too. I have 4k springs with a 5 speed running a single clutch and the truck drives great. The governor springs actually made it easier to drive because 4th gear (in an NV4500 anyway) is now useful when merging onto the interstate, whereas before the truck would just nose over at 2200rpm causing a short shift into 5th and dropping off the turbo.
What does "get ignorant" mean?? And does having a dual disk clutch somehow affect this ignorance?
Edit: Sorry, I was typing the above reply at the same time your were and your answer got posted before mine. My truck doesn't exhibit the issues you're talking about. And it should spring wrap easier than a stock truck considering it's lifted with blocks in the back.
If you have the time and inclination , you could try adjusting the springs a click or two looser to see if that helps with the touchy throttle.
Antonm is offline
