S467/488 - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 07-22-2019, 10:35 AM Thread Starter
Johnf7.3's Avatar
S467/488
Is anyone running a 467/488 looking for ideas on a compound setup for my truck for drag racing
Current set up
Industrial 5x22 injectors
Maxed 12mm pump
26 degrees timming
Full cuts
.93 lines
150lbs valve springs
Billet push rods
Machined O-Ring head
S467
188/220 cam
.20 pistons
Firepunk comp trans
2500 stall converter
Johnf7.3 is offline
post #2 of 6 (permalink) Old 07-23-2019, 12:38 AM
Good god. I hope this is just a play truck. That's a lot of fuel and air! I wouldn't mind playing with that setup for a weekend.
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22*
nSaEvAyL is offline
post #3 of 6 (permalink) Old 07-23-2019, 08:38 AM Thread Starter
Johnf7.3's Avatar
Yea it’s just a weekend toy just wondering how laggy a 488 with the 467 would be
Johnf7.3 is offline
post #4 of 6 (permalink) Old 07-23-2019, 09:44 AM
My guess is you won't light those until you about 2000-2100 rpm. Probably won't hit peak tq until 2400. I ran a single 72 for a while and that is about how it acted. I am guessing this setup will be close. Get turbo blankets for each exhaust housing and double wrap your midpipe. Should help spool. Ceramic coating the housings and midpipe if you can will also help spool
nSaEvAyL is offline
post #5 of 6 (permalink) Old 07-23-2019, 11:49 PM
slpcrf450x's Avatar
I don't have personal experience but I bet it wouldn't be bad considering you have a 2500 stall converter.
You are running the 467 right now? What size housing and turbine do you have? How does it act now as a single?
Tow Pig - 2006 3500 CCLB SRW, G56. Far from stock and still slow
Project - 2002 2500 QCLB SRW, NV5600. Not Running
slpcrf450x is offline
post #6 of 6 (permalink) Old 08-14-2019, 06:50 AM
Sasquatch
crazyrunner33's Avatar
I've played around with the S465 and S467 as singles on my buddy's common rail. I'd recommend the S465 as your secondary for one reason and one reason only. The power below 5 psi.
The S467 flows like a bandit on a 6.7 above 1800 rpm, but it's lazy until that point and hits like a light switch. The 465 with a cast wheel is linear, and it flows a lot at low pressure ratios. I'm driving his truck around this week and accelerating in city traffic(brief acceleration to 50 mph and keeping up with traffic), I don't ever need more than 5 psi. You can probably hit 5 psi on a S465 in compounds on a 12 valve by 1800 rpm or even less.
'97 ECLB NV4500 compound mufflers, Banks stacked with Edge Juice w/Attitude, throttle sensitivity booster, lockup switch, wastegate delete
'10 VW Golf TDI Dieselgate victim, '06 TDI with too much torque
crazyrunner33 is offline
