Exhaust brake valve springs - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 07-16-2019, 07:31 PM Thread Starter
So I’m getting ready to install a 4K gsk. When I bought my truck it came with an banks power exhaust brake and I am wondering which valve spring they installed with that kit. Intake or exhaust?
boss4457 is offline
post #2 of 7 (permalink) Old 07-16-2019, 07:40 PM
myother4x4isaCJ7's Avatar
They should have put exhaust springs in but no guarantee. I would personally replace all of them to be sure they arent all that expensive.... its a good time to replace valve stem seals too.
myother4x4isaCJ7 is offline
post #3 of 7 (permalink) Old 07-16-2019, 07:54 PM Thread Starter
Ok I am going to just keep the rpm below 3200 until I order new springs. If I take one of the valve covers off shouldn’t I be be able to tell if one spring is larger than the other? Also is the front or back valve the exhaust?
boss4457 is offline
post #4 of 7 (permalink) Old 07-16-2019, 08:06 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
If you pulled a set out, you should be able to tell the difference. Intake and exhaust are the same. Pull two out and measure the height and Ill measure one of my stock and let you know.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #5 of 7 (permalink) Old 07-17-2019, 08:14 AM
GAmes's Avatar
iTrader Score: 7 reviews
No need to remove them. The 60 lb springs are barrel shaped, the stockers are straight sided.
GAmes is online now
The Following User Says Thank You to GAmes For This Useful Post:
98whitelightnin (07-17-2019)
post #6 of 7 (permalink) Old 07-18-2019, 01:03 AM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
easy to id
- '96 2500 ECLB
SB-DD
3.54's, Cooper AT3 265's, Studs @ 150ftlb, Custom GSK,
, 055's, AFC Live,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace, SuperSport Headlights,
, couple gauges. 506hp/1080tq
Cowboy303 is offline
post #7 of 7 (permalink) Old 07-22-2019, 12:52 AM
Agreed. The head I just bought has 60s on exhaust side and factory on intake (going to change to 60s). The difference in outside shape is obvious. Plus the 60s have a white stripe painted on.
