Pdd 5x12s with k27 n no fuel plate? - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 52 (permalink) Old 05-16-2019, 10:33 PM Thread Starter
Dmaxdude's Avatar
Would a 4 inch exhaust lower egts considerably or is the stock exhaust straight piped fine?
Dmaxdude is offline
post #14 of 52 (permalink) Old 05-17-2019, 08:46 AM
GAmes's Avatar
iTrader Score: 7 reviews
No. The stock exhaust size will flow just fine to over 400 HP. When my stocker burned out the 4 inch MBRP didn't change my EGTs, at least not enough to read on the gauge.
GAmes is offline
post #15 of 52 (permalink) Old 05-17-2019, 03:28 PM Thread Starter
Dmaxdude's Avatar
Ok thanks!
Dmaxdude is offline
post #16 of 52 (permalink) Old 05-17-2019, 04:11 PM
GAmes's Avatar
That information has been posted dozens of times. A little time to do some research will save you hours while waiting for someone to answer your questions.
GAmes is offline
post #17 of 52 (permalink) Old 05-20-2019, 04:35 PM
alanack6795's Avatar
I have a 160 pump and need new injectors. I would like somewere around 275-350 hp. Should i get 5x12s? Friend of mine said it will run cooler with more fuel at less rack travel; if that makes any sense.
alanack6795 is online now
post #18 of 52 (permalink) Old 05-20-2019, 04:42 PM
The Uppity 12v Guy
dauntless89's Avatar
For a max of 350hp you could go with either 5x12s or stock 215s. I'd see what you can get the best price on.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #19 of 52 (permalink) Old 05-20-2019, 05:37 PM
The 5x12s will get you a shorter injection window but at that power level it is debatable on any real world affects.
Sent from my LG-H932 using Tapatalk
hemirunner426 is online now
post #20 of 52 (permalink) Old 05-20-2019, 06:03 PM
GAmes's Avatar
Originally Posted by hemirunner426 View Post
The 5x12s will get you a shorter injection window ......
Care to expand on that?
GAmes is offline
post #21 of 52 (permalink) Old 05-20-2019, 09:26 PM
The Uppity 12v Guy
Relative to smaller nozzles, larger nozzles deliver a given amount of fuel in a shorter duration. While 300hp, maybe 350hp is attainable on stock 160hp injectors, they become enough of a bottleneck that "full rack" with 160hp injectors results in lots of fuel late in the combustion stroke leading to excessive smoke and high EGTs. A 5x12 at, say half rack travel (spitballing here) will make the same power but with much less smoke and lower EGTs. This effect lessens the larger the nozzles get.
The Following 2 Users Say Thank You to dauntless89 For This Useful Post:
GAmes (05-21-2019), hemirunner426 (05-20-2019)
post #22 of 52 (permalink) Old 05-20-2019, 10:34 PM
So running bigger injectors with a more conservative plate will yeild about the same power with less egts and smoke?
post #23 of 52 (permalink) Old 05-20-2019, 11:06 PM
Potentially yes. It's about the injection window being optimal relative to the piston as it comes to TDC. Too small of injector may put the end of the injection window past TDC and there comes your heat and smoke and some other problems, as an example.
Remember the piston doesn't stop traveling in the bore when the injector opens, sprays, and closes.
post #24 of 52 (permalink) Old 05-20-2019, 11:06 PM
Tony explained it for me.
The Following User Says Thank You to hemirunner426 For This Useful Post:
GAmes (05-21-2019)
Similar Threads
VP44 Diagnostic for everyone. AmT-yd- 98.5-02 Performance Parts Discussion 26 07-27-2016 11:19 AM
Put 2 stroke oil in my fuel?! McKelveyMX 3rd Gen. Performance Parts Discussion 43 08-28-2013 10:26 PM
2002 and newer Chrysler, Dodge Computer DTC Error Codes part 1 Reddevil1 3rd Gen. Powertrain 3 07-25-2012 06:14 PM
Can someone tell me how to fix these codes? cummminsV12 98.5-02 Powertrain 3 09-11-2011 12:04 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
