650hp Build, Nuttin Fancy - Page 3 - Dodge Cummins Diesel Forum
 4Likes
post #25 of 138 (permalink) Old 08-18-2019, 09:33 AM
Drothgeb's Avatar
Originally Posted by Fire god View Post
Fabbing all new brake lines where I can't find stainless to replace factory ones.
Sweet looking build! You might want to consider using nickel/copper lines for the brake lines. Much easier to bend and flare, and wonít crack like stainless sometimes will do. Looks pretty sharp polished too.
1995 4WD RCLB
10.66 sec, 128.93 mph
Under Construction
Drothgeb is offline
post #26 of 138 (permalink) Old 08-18-2019, 11:22 AM
the man in black's Avatar
Thanks. Yes. To the U bolts on the other end.
I like the look of those. Long and tight to the frame. What brand are they? How about sharing a couple pics of the whole truck?
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #27 of 138 (permalink) Old 08-18-2019, 12:25 PM
I did a build very similar to this. Slightly different turbos though. I opted not to get rid of all the painted parts. I just sprayed a very very light coat if clear some of the steel parts. I found out the hard way that paint chips and it only looks good until you have to fix somthing and take those parts off again.
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22* http://s1057.photobucket.com/albums/t398/lwilde13/
nSaEvAyL is offline
post #28 of 138 (permalink) Old 08-18-2019, 04:32 PM Thread Starter
Fire god's Avatar
This is my second build and the paint stuck great the last time. Maybe it's the preparation or the paint.
Either way clear on the steel sounds cool as well.
How many retorques did you do on your ARP's?
95 3500 auto, bhaf, 4k, kdp, gauges, air bags, fuel htr delete, 33"s, dually spacers, 4.10 lim slip, 2" level, silicone hoses, tps delete, tcc switch
Fire god is offline
post #29 of 138 (permalink) Old 08-18-2019, 07:15 PM Thread Starter
Fire god's Avatar
Just some random pics
ID:	854483   Click image for larger version
ID:	854485   Click image for larger version
Fire god is offline
post #30 of 138 (permalink) Old 08-18-2019, 08:08 PM Thread Starter
Fire god's Avatar
Here's the Traction Bars....
I got them from Alligator. They are 65 inches long.
Here's some pics.
ID:	854495   Click image for larger version
ID:	854497   Click image for larger version
Fire god is offline
The Following User Says Thank You to Fire god For This Useful Post:
the man in black (08-18-2019)
post #31 of 138 (permalink) Old 08-18-2019, 09:31 PM
Clean truck man. Clean truck. Sharp.
post #32 of 138 (permalink) Old 08-18-2019, 11:42 PM Thread Starter
Fire god's Avatar
Thanks.
Here's the drive pressure plumbing beginning. Waiting on the particulate filter to arrive.
Fire god is offline
Mjolnir (08-18-2019)
post #33 of 138 (permalink) Old 08-19-2019, 03:17 PM Thread Starter
Fire god's Avatar
Bolts for the after market valve covers including the dual breathers covers needed to be shorter. The shoulder on the stock ones were 20mm. Mc master Carr and now they are 16mm. Perfect.
Fire god is offline
post #34 of 138 (permalink) Old 08-19-2019, 08:37 PM Thread Starter
Fire god's Avatar
Manifold blanket made by Levi. Fit was perfect.
niedhogg likes this.
Fire god is offline
post #35 of 138 (permalink) Old 08-20-2019, 10:38 PM Thread Starter
Fire god's Avatar
Made some progress today. Hung 2 turbos.
Fire god is offline
post #36 of 138 (permalink) Old 08-21-2019, 01:06 PM Thread Starter
Fire god's Avatar
Heat wrap.
Having melted some wire looms in the past I decided this time I'll pay attention to installing heat wrap. Also, I wanted to keep as much heat as possible in the turbo hot side system to keep hood temps down and save heat to use for power expanding in the turbo.
Manifold and both turbos will be blanketed.
All wires and hoses in the entire engine bay will receive Easy Loom or aluminum shielded fiber glass wrap.
It took a long time but it's going to pay off in abrasion protection, heat protection and good looks.
Lava wrap on turbo hot pipes.
ID:	854725   Click image for larger version
ID:	854727   Click image for larger version
ID:	854731   Click image for larger version
ID:	854733   Click image for larger version
Fire god is offline
