650hp Build, Nuttin Fancy - Page 11 - Dodge Cummins Diesel Forum
 4Likes
post #121 of 134 (permalink) Old 11-10-2019, 11:48 AM
If you stumble across the part number for that fan please let us know. I am all about better cooling. That's the biggest problem with high hp 12v's that are pulling trucks.
Did you fab up the charge pipe going from your primary to your intercooler inlet? Wondering why you clocked your turbo that way? I am assuming it was to add clearance between the compressor housing and your manifold?
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22* http://s1057.photobucket.com/albums/t398/lwilde13/
nSaEvAyL is offline
post #122 of 134 (permalink) Old 11-10-2019, 11:50 AM
ekvhekvh's Avatar
Where does the spacer go? Pushes the fan out away from motor?
96 Ram 2500 4x4 automatic. Engine number: ??? Missing.
ekvhekvh is offline
post #123 of 134 (permalink) Old 11-10-2019, 09:14 PM Thread Starter
Fire god's Avatar
In between fan and fan hub.
Pushes fan out from hub.
95 3500 auto, bhaf, 4k, kdp, gauges, air bags, fuel htr delete, 33"s, dually spacers, 4.10 lim slip, 2" level, silicone hoses, tps delete, tcc switch
Fire god is offline
post #124 of 134 (permalink) Old 11-14-2019, 01:48 AM Thread Starter
Fire god's Avatar
Fan is from Genos Garage part FAN-9402-KIT
Flows 39 percent more. It's sourced from 2003 Dodge and up trucks.
Turbo is clocked accordingly by design of Todd from PDD. They fabbed the whole system. Fit was perfect and I didn't have to relocate the battery or remove the trans heat exchanger. Also, I have ready access to the oil filter.
Fire god is offline
post #125 of 134 (permalink) Old 11-14-2019, 12:36 PM
ekvhekvh's Avatar
Adapter from Genos too?
ekvhekvh is offline
post #126 of 134 (permalink) Old 11-14-2019, 12:54 PM Thread Starter
Fire god's Avatar
Originally Posted by ekvhekvh View Post
Adapter from Geno’s too?
Yes, it comes with the kit.
Fire god is offline
post #127 of 134 (permalink) Old 11-19-2019, 04:04 PM
ekvhekvh's Avatar
Thanks much!
ekvhekvh is offline
post #128 of 134 (permalink) Old 01-04-2020, 11:07 AM Thread Starter
Fire god's Avatar
Took a bit of time away to mess with the C6 Z06, so now back to this build.
On-Board Air: Time for the compressors. These are AMP and are sold under Pacbrake name. They have unloaders and check valves.
100 percent duty cycle
3/4 horse
3.1 cfm
22 amps
I'm running two of these. This is the bracket I fabed up. They will be installed where the spare tire used to live. The hot dog air tank will be there as well.
ID:	864339   Click image for larger version
ID:	864341   Click image for larger version
ID:	864343   Click image for larger version
Fire god is offline
post #129 of 134 (permalink) Old 01-07-2020, 08:39 PM Thread Starter
Fire god's Avatar
The compressor project is done. On at 90 and off at 135psi. 44 amp load. I ran two 4 gauge wires from the battery through a 200 amp Stinger solenoid. The solenoid is switched inside the cab. From there through the two fuses and back to rear to t 200 amp 12v relays.
3.4 cfm times two (6.8cfm) at no load. Fills my 3 gallon hot dog tank in one minute.
Very quite. Very happy.
Pacbrake Amp 625's with unloader kits and remote filters.
ID:	864621   Click image for larger version
ID:	864623   Click image for larger version
ID:	864625   Click image for larger version
Fire god is offline
post #130 of 134 (permalink) Old 01-07-2020, 08:48 PM Thread Starter
Fire god's Avatar
More Pics
ID:	864629   Click image for larger version
ID:	864631   Click image for larger version
Fire god is offline
post #131 of 134 (permalink) Old 01-08-2020, 12:23 AM Thread Starter
Fire god's Avatar
New Hubs, Timken Bearings, Calipers, Hawk Pads, SS braided brake lines
Fire god is offline
post #132 of 134 (permalink) Old 01-11-2020, 02:06 AM Thread Starter
Fire god's Avatar
Finished the installation of the Water Meth pump, solenoids, and tank. Fabbed up bracket for pump and solenoids to go under bed next to frame.
ID:	864857   Click image for larger version
ID:	864859   Click image for larger version
ID:	864861   Click image for larger version
Fire god is offline
