Brakes pulling to the right - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 10-07-2013, 01:32 AM Thread Starter
whatsmokin's Avatar
Just last weekend I installed new front brake pads(ceramic), brake rotors and brake calipers on both sides of my truck and a new wheel bearing/hub assembly on the front left and new upper and lower ball joints on both sides(moog). Now when you apply the brakes it pulls to the right, the faster your going and you apply the brakes the worse it is. Im thinking that maybe the rubber line going to the caliper on the left side is starting to collapse inside, but that's just a thought. Im not to familiar with hydraulic brake systems and i need some input from you guys on what you think might be the issue. Thanks in advance
94,95,98 2500 quad cab long bed 4x4 132k miles, 4K GSK, Plateless, Hamilton 188-220 cam, boost elbow, Isspro boost,pyro & tranny temp gauges, DDP .024 DVs, 5in straight pipe, 60# valve springs, ARP head & main studs, Diesel Auto Power 5x.014s, 64/71/14
whatsmokin is offline
post #2 of 6 (permalink) Old 10-07-2013, 10:40 AM
GAmes's Avatar
iTrader Score: 7 reviews
If the flexable brake hoses are the originals replacing them wouldn't hurt. Don't forget the rear one.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #3 of 6 (permalink) Old 10-07-2013, 01:06 PM
Adjust the rear brakes before doing anything else.
http://dieseldatabase.com/adjusting-...-brakes/?id=42
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #4 of 6 (permalink) Old 10-09-2013, 10:31 AM
I had the same problem. There was a blockage in the rubber hose. A later autopsy showed the blockage was near the metal clip that holds it to the truck.
I replaced both lines in front and the rear rubber line. Problem solved.
You can check it by manually bleeding the brakes. If you get low fluid flow there is a blockage. Pull the brake line and have someone step on the brake pedal. Low fluid flow shows a blockage. Keep moving up the line until if flows freely. Be sure to bleed the brakes when you are all done.
Bob
1997 CTD extended cab 4X4 5 speed. Towing package, SLT, BHAF, 4" straight exhaust
Bought 4/28/07
bob95065 is offline
post #5 of 6 (permalink) Old 10-09-2013, 06:52 PM
mdogg54's Avatar
That is Right, BLOCKAGE IN THE HOSE will cause it to pull. I KNOW THIS FOR A FACT. Take it apart and clean it.
mdogg54 is offline
post #6 of 6 (permalink) Old 10-15-2013, 01:29 AM
turbo427's Avatar
allways change the flexlines when doing a brake overhaul, saves problems later,
been there and done that!!
1999 ram 2500, cummins, auto,4wd, reg cab, long bed, , !!! max energy programmer, new 2012 17in wheels and new nitto atrs, rebuilt front end, straight exaust !! air dog 150 gph pump with 1/2in lines to pump with lift press gauge,
turbo427 is offline
