Front brakes gettin hot - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 09-10-2013, 12:24 AM Thread Starter
Dillonabney5's Avatar
Hello guys back again with another amateur diesel driver question. When I bought the truck I noticed a grinding noise when I pressed the brakes, and the rim was getting hot and constantly stayed black. so I took the two front tired off and checked the brakes, they were in bad shape. So I tried changing the Front driver side brakes and the cylinder wouldn't contract in the caliper so I ordered two brand new calipers just to be safe. I changed the calipers and put brand new over sized brake pads on. It is STILL getting hot. You can smell the brakes too even after you get out of the truck. Could anyone please explain what's going on? Thank you all!
Dillon Abney 1996 2500 cummins ext cab long bed
Dillonabney5 is offline
post #2 of 6 (permalink) Old 09-10-2013, 12:34 AM
country_hick's Avatar
Check your rear brakes. They may not be helping at all. Are the rotors to thin? Also, look at your wheel bearings. I doubt they are a problem but if they are to tight or bad they can cause heat.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
The Following User Says Thank You to country_hick For This Useful Post:
Dillonabney5 (09-10-2013)
post #3 of 6 (permalink) Old 09-10-2013, 12:41 AM Thread Starter
The rotors are fine, we changed one, which shouldn't be the cause of it because the other was perfectly fine. But I've seen a few other threads that talked of adjusting the rear brakes. I'll have to look into that. Is it a big job to do?
post #4 of 6 (permalink) Old 09-10-2013, 10:46 AM
GAmes's Avatar
iTrader Score: 7 reviews
The flexable hoses break down internally sometimes and act as a one way check valve. That causes the caliper to not release. If yours are the originals they are due replacement anyway. BTW, spending a little time to learn how to use the search feature will save you having to wait on replies. This info has been poated dozens of times.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #5 of 6 (permalink) Old 09-10-2013, 11:43 AM Thread Starter
Oh well. But I'll check the lines
post #6 of 6 (permalink) Old 09-13-2013, 12:17 PM
Adjusting Rear Drum Brakes
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
