Door Buzzer Disconnect - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 11-12-2011, 10:27 PM Thread Starter
motormayhem's Avatar
Well i finally had it with the door buzzer coming on whenever I had the door open and the key in to listen to music. I really wanted to keep the headlight reminder function working so I found and disconnected just the door alarm part of the buzzer. Took a good bit of searching to find about it so I thought I would share what I figured out with everyone.
Dodge Ram Door Buzzer Disconnect &raquo Motor Mayhem
1997 Laramie SLT 2500 4x4 Longbed: New [email protected]: (Billet TC, Transgo tow/HD shift kit), boost, pyro, trans temp, #6 cam plate, Airaid Intake/Filter, 4" straight pipe, 271K
1984 M1009 CUCV: 6.2L Detroit Diesel, TH400 with Allison TC, 1 Ton Axles, 71k
motormayhem is offline
post #2 of 4 (permalink) Old 11-14-2011, 02:51 PM
When you use that method doesn't it also disable the light around the key hole (halo)?
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 4 (permalink) Old 11-14-2011, 03:18 PM
-SEAN's Avatar
Yeah i did that aswell, it keep spooking deer when i was out hunting.
1997 Dodge 2500,4x4, Afe Intake, 2'' Pacbrake leveling kit w/ Pacbrake Airbags, AutoMeter Colbalts Pyro,Boost,Trans, Flo-Pro 4'' w/ Mbrp tip, 35x12.5 Nitto Mud Graplers on American Outlaw Buckshots, Summit Transmission coming soon
-SEAN is offline
post #4 of 4 (permalink) Old 11-14-2011, 03:44 PM Thread Starter
No, you are only disconnecting the buzzer wire that gets grounded when the key is in the ignition. The rest of the wires running into that plug are still connected so everything but the buzzer with the key in works.
