Interior redo with Chevy console, and Geno's seat foam - Dodge Cummins Diesel Forum
 1Likes
post #1 of 15 (permalink) Old 12-07-2019, 02:05 PM Thread Starter
Antonm's Avatar
So recently I got tired of the stock center console with the aftermarket plastic cup holders. Because if I put a cup in them, the cup would get in the way of shifting gears.
97 Extended cab 4x4, NV4500, gauges, valair single disc clutch, 4k gov springs, +60 lb valve springs, tool steel retainers & locks, homemade #10 plate, medium tension AFC spring & flat washers, 5x13 sac injectors, 055 DVs, stock turbo and manifold for now. Lifted on 37" tires and 4:10 gears.
Antonm is offline
post #2 of 15 (permalink) Old 12-07-2019, 02:07 PM Thread Starter
Antonm's Avatar
So I decided to throw a 2014- 2018 Chevy silverado center console in it.
Antonm is offline
post #3 of 15 (permalink) Old 12-07-2019, 02:08 PM Thread Starter
Antonm's Avatar
But then I still had a driver seat bottom that looked like this to go along with my new console.
Antonm is offline
post #4 of 15 (permalink) Old 12-07-2019, 02:12 PM Thread Starter
Antonm's Avatar
But I didn't want to spend good money covering up the twenty year old driver seat foam, so Geno's to the rescue..
Antonm is offline
post #5 of 15 (permalink) Old 12-07-2019, 02:14 PM Thread Starter
Antonm's Avatar
A quick trip down to my local veteran owned trim and upholstery shop to get the 90's knocked out of the truck . Seriously , who thought the little yellow and red dots in the gray fabric was a good idea.
Antonm is offline
post #6 of 15 (permalink) Old 12-07-2019, 02:18 PM Thread Starter
Antonm's Avatar
Also had them do the headliner, sun visors and door fabric inserts while I was there. For whatever reason my black exterior and gray interior truck, had a tan/ brown headliner stock, so now its black like it should've always been.
ID:	862283   Click image for larger version
Antonm is offline
post #7 of 15 (permalink) Old 12-07-2019, 02:25 PM Thread Starter
Antonm's Avatar
The only negative (and it might not really be a negative after i get used to it) is that the new Geno's set foam is a LOT thicker than my old broken down one and now I sit a LOT higher in the truck.
Like I had to readjust both outside mirrors and the steering wheel tilt setting from where I've always had them up some, its a noticeable difference.
I'll guess I'll just have to get used to driving the truck again , but now my knee is hitting the back of the steering wheel when coming off the clutch and that never used to happen before. Maybe the new foam will settle in after a little bit , or I'll figure out a way to adjust my clutch foot position (sure wish the Dodge had a telescopic adjustment on the steering column , that would fix everything)
Antonm is offline
post #8 of 15 (permalink) Old 12-07-2019, 02:34 PM Thread Starter
Antonm's Avatar
Oh yeah, I had the back seat done as well just to match everything. The stock back seat was actually in pretty good shape for its age , but I had them recover it anyway.
Antonm is offline
post #9 of 15 (permalink) Old 12-07-2019, 02:36 PM
Nice job!
My drivers seat cushion will need to be replaced soon. Seems like Geno’s is the way to go.
Sent from my iPhone using Tapatalk Pro
2012 CCSB Laramie
6.7, 68RFE
EFI Live, Flo Pro/factory exhaust, gauges and Edge Insight.
Mike D Texas is offline
post #10 of 15 (permalink) Old 12-07-2019, 02:41 PM
Definitely looks better. I have foam and a cover sitting in the Geno's shopping cart along with some other things I want to get. Really like your console swap.
morphrider is offline
post #11 of 15 (permalink) Old 12-07-2019, 03:42 PM
Stox225's Avatar
How much was the upholstery work?
1997 Cummins 2500; NV4500HD; SB DD; 315/75R16; Spohn Performance 3rd Gen Track Bar; Core 4x4 Adjustable Control Arms; 98-99HD Steering; Spohn Performance Steering Gear Box Stabilizer; 63/65/14; AFC Live; PDD 7mm DV's; 4 GSK; Mac Rack Plug; Custom Fuel System; PDD 5x.012; Colt Cam "Big Stick"; 60# Springs; PDD Stage 1 Push Rods; O-Ring Head; Head Studs; KDP Fix; Fluidampr; Boost/EGT/FP Gauges; BHAF; Interior Modifications
Stox225 is online now
post #12 of 15 (permalink) Old 12-07-2019, 04:34 PM Thread Starter
Antonm's Avatar
I paid them $800 in cash for everything (tax included. $800 was out the door total). I did provide the Geno's cushion to them though.
Lots of small, privately owned, local type businesses will discount there prices pretty good if you walk in with green folding money. The credit card companies/ banks really do kinda stick it to the little guys with fee's and if you pay with cash, they can get around some of those fees.
After the upholstery shop, cushion, and center console costs, I probably have about $1200-1300 total in my interior redo. Hopefully the interior will be go-to-go for another twenty years now.....Well, maybe I'll do something with carpet before another twenty years passes, but that should be it.
Stox225 likes this.
Antonm is offline
