Beating the dead horse DASH - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 11-08-2019, 04:31 AM Thread Starter
ddurr92's Avatar
I love pretty much everything about my truck except for the dash that crumbles with almost every huge pot hole i hit.. the dash rattles itself apart, and Lord forbid if i have to turn on the headlights or press my OD off switch when pulling a load. The dash breaks like an old cookie.
Ive seen where people use about everything to fix the issues , from top covers to using no dash at all. I however would love to keep my truck looking nice but this dash assembly looks terrible.
I cannot fathom spending 800$ on a junkyard dash to only find it crumbly like mine. I don't want to get halfway threw the dash swap and then have to put everything back together cause the used dash is broken in important areas.
Once this original dash is gone, i don't want to ever see it again. I wish i knew people with 3D printers and knew every single part of the dash assembly so we could get new assemblies made for these trucks.
Has anyone actually made a decent looking dash for 1994-1996 trucks?? I want to be able to take my truck to car shows and antique auto shows and not be concerned with an ugly dash...
Sent from my SM-N975U using Tapatalk
ddurr92 is offline
post #2 of 19 (permalink) Old 11-08-2019, 10:49 AM
Killjoy's Avatar
I was looking at a fiberglass replacement dash for around $350. Its obviously gonna need to be finished off as far as holes, gelcoat, primer, paint, fitment etc. But it probably wont ever crack again.
I too can not stand the dodge dashes and this one on my 95 has just about had it, although it is still bolted up, it did so in three different pieces...
2002 ram 2500 quad cab shortbed ST. Red, 4x4, nv4500 swap 24v, 66mm silver bullet, 100hp injectors , fass titanium 150, 4" exhaust, guages. 190k miles.
Killjoy is offline
post #3 of 19 (permalink) Old 11-08-2019, 11:14 AM
jimduchek's Avatar
Details??? I'm in the same boat as the OP, i've been considering picking up a junkyard dash and then dipping the whole dang thing in epoxy or something. Literally everything is falling apart and i don't trust a used dash not to do the same. My climate control is no longer screwed into anything, the OD/fog switch screws are broke off, the cupholder screws are broke, the radio screws are broke. The ashtray is still hangin in there though haha..
1997 2500 CCLB, NV4500, 4.10s.
jimduchek is offline
post #4 of 19 (permalink) Old 11-08-2019, 11:23 AM
Killjoy's Avatar
https://www.amazon.com/94-97-DODGE-D.../dp/B06WRSPXLN
Killjoy is offline
post #5 of 19 (permalink) Old 11-08-2019, 11:34 AM
Antonm's Avatar
I think that's just the top and doesn't include the actual dash structure that is also brittle/ prone to breakage.
97 Extended cab 4x4, NV4500, gauges, valair single disc clutch, 4k gov springs, +60 lb valve springs, homemade #10 plate, medium tension AFC spring, flat washers AFC diaphragm, stock turbo and injectors, lifted on 37" tires with re-stacked limited slip friction plates, and factory 4:10 gears.
Antonm is offline
post #6 of 19 (permalink) Old 11-08-2019, 12:05 PM
Killjoy's Avatar
I believe you are correct. As far as the dash frame under the dash, I think there is no hope in the aftermarket world. And I know if I went to pull a junkyard dash, I would end up destroying it. ESPECIALLY since mine is red, and they didnt make very many of the red interiors.
Killjoy is offline
post #7 of 19 (permalink) Old 11-08-2019, 12:53 PM
They are not that difficult to remove - you should be able to get one out without damaging it, if you are careful. I've seen writeups in here somewhere (or maybe linked in the stickies) about R&Ring the dash. It might be covered in a heater-core or AC-case thread, too. I used one of those writeups to guide me through pulling a complete assembly and a bottom assembly in salvage yards.
As for the color, you could take the interior-color info (code or color name) from your door sticker to an automotive paint shop and get rattle cans or a pint/quart (if you have a compressor and spray gun) made up in the correct color and repaint the dash.
'96 2500 club-cab, long bed, 2WD - Dipricol trans/boost/pyro gauges, ISSPRO fuel pressure gauge, +2qt Chrysler trans pan, Sport headlight retrofit & suvlights conversion harness, fuel heater deleted, KDP tabbed, Raybestos WC37290 (1-1/16") wheel cylinders
texasprd is offline
post #8 of 19 (permalink) Old 11-08-2019, 01:06 PM
Killjoy's Avatar
Done my fare share of dash removals on these. Easy enough to get em in and out. Just incredibly brittle.
Sorry about the sideways pics, but this is my 95 I got cheap, and I had to tear out the ENTIRE interior to get all the dead rodents out. Guy I bought it from said header cable was stuck, probably had nothing to do with the rats nest on top of the hvac box. Lol
ID:	860123   Click image for larger version
Killjoy is offline
post #9 of 19 (permalink) Old 11-08-2019, 06:29 PM
https://www.lmctruck.com/1994-15-dod...strument-bezel
BIG BLUE 1996 2500 Banks,gearvenders,5th geardone. KDP pinned..... 1995 Scotty Motorhome Banks, Pot Mod. KDP tabbed......." Convictions are more dangerous foes of truth than lies." { Nietzsche}
1996dram is offline
post #10 of 19 (permalink) Old 11-08-2019, 07:17 PM
jimduchek's Avatar
That's just the bezel and the dash top. Not the main structural piece.
I did look up the p/n once and there _are_ a few NOS dashes available around, in some colors. No grey, I don't think. Think they were running around $1k.
post #11 of 19 (permalink) Old 11-08-2019, 07:27 PM
country_hick's Avatar
You can use vinyl dye to "paint" a dash the correct color. It is not a cheap product if it is a good quality product.
The solution for a lower dash replacement will come when someone decides to make one for themselves, makes a mold, and then sees the opportunity to make money by offering the same part to others. Making a (2 piece minimum) mold from a solid dash should not be that hard. It would however take a lot of time to make the mold and to make fiberglass replacements.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #12 of 19 (permalink) Old 11-08-2019, 09:48 PM
Killjoy's Avatar
I had often times thought about something like this, with metal braces molded in, etc.
Killjoy is offline
