PSC SG-851 steering box - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 12-11-2018, 03:03 PM Thread Starter
The Steering box on my truck is about due to be replaced. I came across the PSC SG-851, but I cant find many reviews of it. Lots of stuff about the steering boxes they make for jeeps though.
Does anyone here have any experience with them they would like to share?
1998 2500 Quad Cab 4X4, 16* timing, 4" exhaust, TT OFV, FASS, FASS sump W/draw straw, BHAF, boost, EGT, FP, Gauges, Stage 2 Transmission from Randy's, AFC Live, 5x.011 injectors, 025 DV, K27 turbo.
BobJK is offline
post #2 of 18 (permalink) Old 12-16-2018, 07:25 PM
Armchair Mechanic
colin91's Avatar
I have that box and I would do it again. I recommend getting the PSC high flow pump as well to keep up with the bigger box especially if you are running larger tires. Just know that because the box is larger it has spacers that come with it to push it off the frame a little bit, this in turn makes it impossible to align your steering wheel center without modifying (shortening) the drag link.
1996 2500 ECLB, NV4500, 4X4
Engine: 24 Valve P-Pump Swapped, Crowler Springs, Adj. Timing Gear @ 20*, Haisley L19 studs, DAP 3 Piece Mani, Fluidampr, Southbend DD3250, 5" Exhaust+FTE Resonator
Air: HE351VE w/ Banshee Controller
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055s, AirDog II 165, Dual Feed, #0 plate, 4K GSK
Suspension: Thuren 3" Coils, Thuren Sway Bar, DOR Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Synergy Steering, Fox 2.0 IFPs, Yukon Hub Conversion, Dynatrac BJs, 37x12.5x17 Toyo M/T's on H2s
colin91 is offline
post #3 of 18 (permalink) Old 12-16-2018, 08:03 PM Thread Starter
Thanks! I’m running A Synergy drag link and tie rod, it has tons of adjustment.
BobJK is offline
post #4 of 18 (permalink) Old 12-17-2018, 09:45 PM
Armchair Mechanic
colin91's Avatar
I have the same Synergy Steering and it still doesn't have enough adjustment. I cut about 3/4" - 1" out of it, welded it back together and welded a sleeve over the outside of the weld area for extra strength.
You either have to modify the drag link or get a custom short one made. The other option is notching and welding the the frame so the box can sit flush against it like a stock style box and throw the spacers away.
colin91 is offline
post #5 of 18 (permalink) Old 12-18-2018, 06:30 PM
Fire god's Avatar
Red Head with the Borgeson high flow pump. Bolted right up.
95 3500 auto, bhaf, 4k, kdp, gauges, air bags, fuel htr delete, 33"s, dually spacers, 4.10 lim slip, 2" level, silicone hoses, tps delete, tcc switch
Fire god is offline
post #6 of 18 (permalink) Old 12-19-2018, 08:41 AM
blackDOHC's Avatar
The 852K3(T style) box from PSC comes with a shorter tie rod for the drag link.
1997 ECLB - 5" Diamond Eye straight pipe - ISSpro Trans temp/EGT/Boost - AFC Live - boost elbow - 191s - Built trans - BHAF - ARP 425s - PSC SG852 - 315/75/16
blackDOHC is offline
post #7 of 18 (permalink) Old 12-20-2018, 09:46 AM Thread Starter
That would be great if i was running the stock drag link, unfourtantly I have the Synergy tie rod and drag link on my truck, and I'm unwilling to give them up. It sounds like it has to be shortened up quite a bit to make this set up work.
BobJK is offline
post #8 of 18 (permalink) Old 12-20-2018, 01:22 PM
blackDOHC's Avatar
I just figured I would through that bit of info out for anyone stumbling across this thread looking for info on the PSC box.
I should be buying one here soon, I've heard nothing but good things about it.
post #9 of 18 (permalink) Old 12-26-2018, 09:52 AM Thread Starter
I emailed Synergy, and they have no plans to offer a drag link to fit this steering gear box at this time.
BobJK is offline
post #10 of 18 (permalink) Old 04-16-2019, 09:15 AM
blackDOHC's Avatar
I thought I would bump this.
I have had my PSC 852K3 box installed for a couple months now and I can't imagine going back to an OEM style box. Best steering improvement I have bought for this truck. I was able to pick it up for a hair over $600 shipped to my door as well.
post #11 of 18 (permalink) Old 04-16-2019, 12:25 PM
So what did you do about the Drag Link length?
Thanks
'96' CCLB SLT, 4x4, 12V, (68RFE, Rev Max TC, VB work), KDP, '98' Spt. Hdlt.,Pwr Tow Mir., gauges, 16*, 4K GSK, 60#'s, TT AOFV, 3pc Ex., PDD 5x12's, HE351cw, AFCLive, TB 4" Ex., BHAF, 265x75x16's, Str. Bx Brace, HD Str., Red-Head, Air Bag's
63willys is online now
post #12 of 18 (permalink) Old 04-16-2019, 12:42 PM
blackDOHC's Avatar
Thanks
I'm using stock style parts and it came with a shortened drag link tie rod end. So I have plenty of adjustment.
The Following User Says Thank You to blackDOHC For This Useful Post:
63willys (04-16-2019)
