2001 2500: Another bad automatic transmission - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 11-29-2014, 08:19 AM Thread Starter
First post ladies and gentlemen, so a thank you up front is in order.
Now to the problem, I just bought this 2001 5.9 2500, automatic trans 6 weeks ago, no mods...other than larger tires and 100K miles on it. A real cream-puff Southern truck, or so I thought.
After sorting the do's and dont's with the overdrive, I started to notice the transmission lurching quickly back and forth when at slow speed going up my steep driveway. Dropping it into 2nd cured that. At highway speed, I would sometimes need to lift to get it into 4th. Cut to Thanksgiving day driving on the highway, cruising at 60 the tranny would jump up to 1700rpm from 1600, and then from 1600 to 1900. A really quick slip. I had just been driving in deep snow, so I pulled off (after about 20 miles) to see if there was any blockage or anything noticeable I could fix on the fly. Shut it off, looked around for a few minutes, plenty of fluid... though it smelled a bit burnt. Started it up and went on my way. The problem stopped.
Drove home that night, 1 1/2 hrs on highway, as I was coming up a steep hill on surface a road, I noticed it not shifting up from 2-3. Got home fine, had to feed the animals and do a little plowing, left the engine running for about 25 minutes, hopped back in to go to a friends house. Sounded now like it was stuck in second, had to stop on a steep hill as the tranny now was just slipping and smoking. Backed it down the hill about 1/4 mile, was able to nurse it into drive and get myself home.
I haven't pulled the pan yet, not that I'd know really what I was looking at as I haven't owned a truck newer than a 1972. But I was going to see if there were parts in the pan, condition of the filter, fluid etc..
I will likely need a new transmission, and reading the horror stories about people having rebuilds only to have the same troubles again, I was wondering what you would suggest? A beefier after market trans or....???
Thanks, John
EDIT* I placed this here because I am a farmer and NEED this truck back on the road for animal hauling asap....92 views and no responses?
Any input as to whether it sounds like a pressure solenoid gone bad which led to a catastrophic failure would be helpful, or whether that's even possible. In fact any help would be helpful!
defdes is offline
post #2 of 6 (permalink) Old 12-05-2014, 03:29 PM
cms829's Avatar
I'll TRY to help. As stated below I am just a guy who works on my own truck. I actually just literally finished rebuilding my own 48RE a day ago.
I believe that you have a 47re? Maybe not...Im not too familiar with those years. But regardless it sounds like the governor solenoid or pressure transducer. Thats a lot of symptoms.... all seem like they could point to the solenoid and transducer though.
Im not a professional by any means though and I am not even sure what trans you have. Not sure what you mean by sorting the do's and dont's with the overdrive either?
2004 3500 4x4 SRW QC - 48RE self built @ 202K with lots of goodies - HE351CW, S&B CAI, 08 front clip, Edge Juice with Attitude CTS2, Silverline 4" exhaust, Cometic Gskts
cms829 is offline
post #3 of 6 (permalink) Old 12-05-2014, 03:34 PM
cms829's Avatar
Also - start simple! You said the fluid level was good? but smelled a little burnt? How many miles on the trans and do you know if it was serviced regularly?
You can do one adjustment without dropping the pan and that would be the second gear band - but doesnt sound like thats your main issue as dropping it into manual second helped you climb that hill. And regardless second gear is the ONLY gear that the intermediate band is applied in.
Your forward clutches are applied in EVERY gear. Your overdrive direct clutches are applied in 1st,2nd, and 3rd. Just an FYI....
and here is some reading for you - Write down your symptoms. Then read and find out what the cause is. Look for the common denominator and start there.
HARSH ENGAGEMENT (FROM NEUTRAL TO DRIVE OR REVERSE)
1. Fluid Level Low. Add Fluid
2. Throttle Linkage Mis-adjusted. Adjust linkage - setting may be too long.
3. Mount and Driveline Bolts Loose. Check engine mount, transmission mount, propeller shaft, rear spring to body bolts, rear control arms, crossmember and axle bolt torque. Tighten loose bolts and replace missing bolts.
4. U-Joint Worn/Broken. Remove propeller shaft and replace U-Joint.
5. Axle Backlash Incorrect. Check per Service Manual. Correct as needed.
6. Hydraulic Pressure Incorrect. Check pressure. Remove, overhaul or adjust valve body as needed.
7. Band Mis-adjusted. Adjust rear band.
8. Valve Body Check Balls Missing. Inspect valve body for proper check ball installation.
9. Axle Pinion Flange Loose. Replace nut and check pinion threads before installing new nut. Replace pinion gear if threads are damaged.
10. Clutch, band or planetary component damaged. Remove, disassemble and repair transmission as necessary.
11. Converter Clutch Faulty. Replace converter and flush cooler and line before installing new converter.
DELAYED ENGAGEMENT (FROM NEUTRAL TO DRIVE OR REVERSE)
1. Fluid Level Low. Correct level and check for leaks.
2. Filter Clogged. Change filter.
3. Gearshift Linkage Mis-adjusted. Adjust linkage and repair linkage if worn or damaged.
4. Torque Converter Drain Back (Oil drains from torque converter into transmission sump). If vehicle moves normally after 5 seconds after shifting into gear, no repair is necessary. If longer, inspect pump bushing for wear. Replace pump house.
5. Rear Band Mis-adjusted. Adjust band.
6. Valve Body Filter Plugged. Replace fluid and filter. If oil pan and old fluid were full of clutch disc material and/or metal particles, overhaul will be necessary.
7. Oil Pump Gears Worn/Damaged. Remove transmission and replace oil pump.
8. Governor Circuit and Solenoid Valve Electrical Fault. Test with DRBŪ scan tool and repair as required.
9. Hydraulic Pressure Incorrect. Perform pressure test, remove transmission and repair as needed.
10. Reaction Shaft Seal Rings Worn/Broken. Remove transmission, remove oil pump and replace seal rings.
11. Rear Clutch/Input Shaft, Rear Clutch Seal Rings Damaged. Remove and disassemble transmission and repair as necessary.
12. Regulator Valve Stuck. Clean.
13. Cooler Plugged. Transfer case failure can plug cooler.
NO DRIVE RANGE (REVERSE OK)
1. Fluid Level Low. Add fluid and check for leaks if drive is restored.
2. Gearshift Linkage/Cable Loose/Misadjusted. Repair or replace linkage components.
3. Rear Clutch Burnt. Remove and disassemble transmission and rear clutch and seals. Repair/replace worn or damaged parts as needed.
4. Valve Body Malfunction. Remove and disassemble valve body. Replace assembly if any valves or bores are damaged.
5. Transmission Overrunning Clutch Broken. Remove and disassemble transmission. Replace overrunning clutch.
6. Input Shaft Seal Rings Worn/Damaged. Remove and disassemble transmission. Replace seal rings and any other worn or damaged parts.
7. Front Planetary Failed Broken. Remove and repair.
NO DRIVE OR REVERSE (VEHICLE WILL NOT MOVE)
2. Gearshift Linkage/Cable Loose/Misadjusted. Inspect, adjust and reassemble linkage as needed. Replace worn/damaged parts.
3. U-Joint/Axle/Transfer Case Broken. Perform preliminary inspection procedure for vehicle that will not move. Refer to procedure in diagnosis section.
4. Filter Plugged. Remove and disassemble transmission. Repair or replace failed components as needed. Replace filter. If filter and fluid contained clutch material or metal particles, an overhaul may be necessary. Perform lube flow test. Flush oil. Replace cooler as necessary.
5. Oil Pump Damaged. Perform pressure test to confirm low pressure. Replace pump body assembly if necessary.
6. Valve Body Malfunctioned. Check and inspect valve body. Replace valve body (as assembly) if any valve or bore is damaged. Clean and reassemble correctly if all parts are in good condition.
7. Transmission Internal Component Damaged. Remove and disassemble transmission. Repair or replace failed components as needed.
8. Park Sprag not Releasing - Check Stall Speed, Worn/Damaged/Stuck. Remove, disassemble, repair.
9. Torque Converter Damage. Inspect and replace as required.
SHIFTS DELAYED OR ERRATIC (SHIFTS ALSO HARSH AT TIMES)
1. Fluid Level Low/High. Correct fluid level and check for leaks if low.
2. Fluid Filter Clogged. Replace filter. If filter and fluid contained clutch material or metal particles, an overhaul may be necessary. Perform lube flow test.
3. Throttle Linkage Mis-adjusted. Adjust linkage as described in service section.
4. Throttle Linkage Binding. Check cable for binding. Check for return to closed throttle at transmission.
5. Gearshift Linkage/Cable Mis-adjusted. Adjust linkage/cable as described in service section.
6. Clutch or Servo Failure. Remove valve body and air test clutch, and band servo operation. Disassemble and repair transmission as needed.
7. Governor Circuit Electrical Fault. Test using DRBŪ scan tool and repair as required.
8. Front Band Mis-adjusted. Adjust band.
9. Pump Suction Passage Leak. Check for excessive foam on dipstick after normal driving. Check for loose pump bolts, defective gasket. Replace pump assembly if needed.
NO REVERSE (D RANGES OK)
1. Gearshift Linkage/Cable Mis-adjusted/Damaged. Repair or replace linkage parts as needed.
2. Park Sprag Sticking. Replace overdrive annulus gear.
3. Rear Band Mis-adjusted/Worn. Adjust band; replace.
4. Valve Body Malfunction. Remove and service valve body. Replace valve body if any valves or valve bores are worn or damaged.
5. Rear Servo Malfunction. Remove and disassemble transmission. Replace worn/damaged servo parts as necessary.
6. Direct Clutch in Overdrive Worn. Disassemble overdrive. Replace worn or damaged parts.
7. Front Clutch Burnt. Remove and disassemble transmission. Replace worn, damaged clutch parts as required.
HAS FIRST/REVERSE ONLY (NO 1-2 OR 2-3 UPSHIFT)
1. Governor Circuit Electrical Fault. Test using DRBŪ scan tool and repair as required.
2. Valve Body Malfunction. Repair stuck 1-2 shift valve or governor plug.
3. Front Servo/Kickdown Band Damaged/Burned. Repair/replace.
MOVES IN 2ND OR 3RD GEAR, ABRUPTLY DOWNSHIFTS TO LOW
1. Valve Body Malfunction. Remove, clean and inspect. Look for stuck 1-2 valve or governor plug.
NO LOW GEAR (MOVES IN 2ND OR 3RD GEAR ONLY)
1. Governor Circuit Electrical Fault. Test with DRBŪ scan tool and repair as required.
2. Valve Body Malfunction. Remove, clean and inspect. Look for sticking 1-2 shift valve, 2-3 shift valve, governor plug or broken springs.
3. Front Servo Piston ed in Bore. Inspect servo and repair as required.
4. Front Band Linkage Malfunction Inspect linkage and look for bind in linkage.
NO KICKDOWN OR NORMAL DOWNSHIFT
1. Throttle Linkage Mis-adjusted. Adjust linkage.
2. Accelerator Pedal Travel Restricted. Verify floor mat is not under pedal, repair worn accelerator cable or bent brackets.
3. Valve Body Hydraulic Pressures Too High or Too Low Due to Valve Body Malfunction or Incorrect Hydraulic Control Pressure Adjustments. Perform hydraulic pressure tests to determine cause and repair as required. Correct valve body pressure adjustments as required.
4. Governor Circuit Electrical Fault. Test with DRBŪ scan tool and repair as required.
5. Valve Body Malfunction. Perform hydraulic pressure tests to determine cause and repair as required. Correct valve body pressure adjustments as required.
6. TPS Malfunction. Replace sensor, check with DRBŪ scan tool.
7. PCM Malfunction. Check with DRBŪ scan tool and replace if required.
8. Valve Body Malfunction. Repair sticking 1-2, 2-3 shift valves, governor plugs, 3-4 solenoid, 3-4 shift valve, 3-4 timing valve.
STUCK IN LOW GEAR (WILL NOT UPSHIFT)
1. Throttle Linkage Mis-adjusted/Stuck. Adjust linkage and repair linkage if worn or damaged. Check for binding cable or missing return spring.
2. Gearshift Linkage Mis-adjusted. Adjust linkage and repair linkage if worn or damaged.
3. Governor Component Electrical Fault. Check operating pressures and test with DRBŪ scan tool, repair faulty component.
4. Front Band Out of Adjustment. Adjust Band.
5. Clutch or Servo Malfunction. Air pressure check operation of clutches and bands. Repair faulty component.
CREEPS IN NEUTRAL
1. Gearshift Linkage Mis-adjusted. Adjust linkage.
2. Rear Clutch Dragging/Warped. Disassemble and repair.
3. Valve Body Malfunction. Perform hydraulic pressure test to determine cause and repair as required.
BUZZING NOISE
1. Fluid Level Low Add fluid and check for leaks.
2. Shift Cable Mis-assembled. Route cable away from engine and bell housing.
3. Valve Body Mis-assembled. Remove, disassemble, inspect valve body. Reassemble correctly if necessary. Replace assembly if valves or springs are damaged. Check for loose bolts or screws.
4. Pump Passages Leaking. Check pump for porous casting, scores on mating surfaces and excess rotor clearance. Repair as required. Loose pump bolts.
5. Cooling System Cooler Plugged. Flow check cooler circuit. Repair as needed.
6. Overrunning Clutch Damaged. Replace clutch.
SLIPS IN REVERSE ONLY
1. Fluid Level Low. Add fluid and check for leaks.
2. Gearshift Linkage Mis-adjusted. Adjust linkage.
3. Rear Band Mis-adjusted. Adjust band.
4. Rear Band Worn. Replace as required.
5. Overdrive Direct Clutch Worn. Disassemble overdrive. Repair as needed.
6. Hydraulic Pressure Too Low. Perform hydraulic pressure tests to determine cause.
7. Rear Servo Leaking. Air pressure check clutch-servo operation and repair as required.
8. Band Linkage Binding. Inspect and repair as required.
SLIPS IN FORWARD DRIVE RANGES
2. Fluid Foaming. Check for high oil level, bad pump gasket or seals, dirt between pump halves and loose pump bolts. Replace pump if necessary.
3. Throttle Linkage Mis-adjusted. Adjust linkage.
4. Gearshift Linkage Mis-adjusted. Adjust linkage.
5. Rear Clutch Worn. Inspect and replace as needed.
6. Low Hydraulic Pressure Due to Worn Pump, Incorrect Control Pressure Adjustments, Valve Body Warpage or Malfunction, Sticking, Leaking Seal Rings, Clutch Seals Leaking, Servo Leaks, Clogged Filter or Cooler Lines. Perform hydraulic and air pressure tests to determine cause.
7. Rear Clutch Malfunction, Leaking Seals or Worn Plates. Air pressure check clutch-servo operation and repair as required.
8. Overrunning Clutch Worn, Not Holding (Slips in 1 Only). Replace Clutch.
SLIPS IN LOW GEAR "D" ONLY, BUT NOT IN MANUAL 1 POSITION
Overrunning Clutch Faulty. Replace overrunning clutch.
GROWLING, GRATING OR SCRAPING NOISES
1. Drive Plate Broken. Replace.
2. Torque Converter Bolts Hitting Dust Shield. Dust shield bent. Replace or repair.
3. Planetary Gear Set Broken/Seized. Check for debris in oil pan and repair as required.
4. Overrunning Clutch Worn/Broken. Inspect and check for debris in oil pan. Repair as required.
5. Oil Pump Components Scored/Binding. Remove, inspect and repair as required.
6. Output Shaft Bearing or Bushing Damaged. Remove, inspect and repair as required.
7. Clutch Operation Faulty. Perform air pressure check and repair as required.
8. Front and Rear Bands Mis-adjusted. Adjust bands.
DRAGS OR LOCKS UP
1. Fluid Level Low. Check and adjust level.
2. Clutch Dragging/Failed Air pressure check clutch operation and repair as required.
3. Front or Rear Band Mis-adjusted. Adjust bands.
4. Case Leaks Internally. Check for leakage between passages in case.
5. Servo Band or Linkage Malfunction. Air pressure check servo operation and repair as required.
6. Overrunning Clutch Worn. Remove and inspect clutch. Repair as required.
7. Planetary Gears Broken. Remove, inspect and repair as required (look for debris in oil pan).
8. Converter Clutch Dragging. Check for plugged cooler. Perform flow check. Inspect pump for excessive side clearance. Replace pump as required.
NO 4-3 DOWNSHIFT
1. Circuit Wiring and/or Connectors Shorted. Test wiring and connectors with test lamp and volt/ohmmeter. Repair wiring as necessary. Replace connectors and/or harnesses as required.
2. PCM Malfunction. Check PCM operation with DRBŪ scan tool. Replace PCM only if faulty.
3. TPS Malfunction Check TPS with DRBŪ scan tool at PCM.
4. Lockup Solenoid Not Venting. Remove valve body and replace solenoid assembly if plugged or shorted.
5. Overdrive Solenoid Not Venting. Remove valve body and replace solenoid if plugged or shorted.
6. Valve Body Valve Sticking. Repair stuck 3-4 shift valve or lockup timing valve.
NO 4-3 DOWNSHIFT WHEN CONTROL SWITCH IS TURNED OFF
1. Control Switch Open/Shorted. Test and replace switch if faulty.
2. Overdrive Solenoid Connector Shorted. Test solenoids and replace if seized or shorted.
3. PCM Malfunction. Test with DRBŪ scan tool. Replace PCM if faulty.
4. Valve Body Stuck Valves. Repair stuck 3-4, lockup or lockup timing valve.
CLUNK NOISE FROM DRIVELINE ON CLOSED THROTTLE 4-3 DOWNSHIFT
1. Transmission Fluid Low. Add Fluid.
2. Throttle Cable Mis-adjusted. Adjust cable.
3. Overdrive Clutch Select Spacer Wrong Spacer. Replace overdrive piston thrust plate spacer.
3-4 UPSHIFT OCCURS IMMEDIATELY AFTER 2-3 SHIFT
1. Overdrive Solenoid Connector or Wiring Shorted. Test connector and wiring for loose connections, shorts or ground and repair as needed.
2. TPS Malfunction. Test TPS and replace as necessary. Check with DRBŪ scan tool.
3. PCM Malfunction. Test PCM with DRBŪ scan tool and replace controller if faulty.
4. Overdrive Solenoid Malfunction. Replace solenoid.
5. Valve Body Malfunction. Remove, disassemble, clean and inspect valve body components. Make sure all valves and plugs slide freely in bores. Polish valves with crocus cloth if needed.
WHINE/NOISE RELATED TO ENGINE SPEED
2. Shift Cable Incorrect Routing. Check shift cable for correct routing. Should not touch engine or bell housing.
NO 3-4 UPSHIFT
1. O/D Switch In OFF Position. Turn control switch to ON position.
2. Overdrive Circuit Fuse Blown. Replace fuse. Determine why fuse failed and repair as necessary (i.e., shorts or grounds in circuit).
3. O/D Switch Wire Shorted/Open Cut. Check wires/connections with 12V test lamp and voltmeter. Repair damaged or loose wire/connection as necessary.
4. Distance or Coolant Sensor Malfunction. Check with DRBŪ scan tool and repair or replace as necessary.
5. TPS Malfunction. Check with DRBŪ scan tool and replace if necessary.
6. Neutral Sense to PCM Wire Shorted/Cut. Test switch/sensor as described in service section and replace if necessary. Engine no start.
7. PCM Malfunction. Check with DRBŪ scan tool and replace if necessary.
8. Overdrive Solenoid Shorted/Open. Replace solenoid if shorted or open and repair loose or damaged wires (DRBŪ scan tool).
9. Solenoid Feed Orifice in Valve Body Blocked. Remove, disassemble, and clean valve body thoroughly. Check feed orifice.
10. Overdrive Clutch Failed. Disassemble overdrive and repair as needed.
11. Hydraulic Pressure Low. Pressure test transmission to determine cause.
12. Valve Body Valve Stuck. Repair stuck 3-4 shift valve, 3-4 timing valve.
13. O/D Piston Incorrect Spacer. Remove unit, check end play and install correct spacer.
14. Overdrive Piston Seal Failure. Replace both seals.
15. O/D Check Valve/Orifice Failed. Check for free movement and secure assembly (in piston retainer). Check ball bleed orifice.
SLIPS IN OVERDRIVE FOURTH GEAR
2. Overdrive Clutch Pack Worn. Remove overdrive unit and rebuild clutch pack.
3. Overdrive Piston Retainer Bleed Orifice Blown Out. Disassemble transmission, remove retainer and replace orifice.
4. Overdrive Piston or Seal Malfunction. Remove overdrive unit. Replace seals if worn. Replace piston if damaged. If piston retainer is damaged, remove and disassemble the transmission.
5. 3-4 Shift Valve, Timing Valve or Accumulator Malfunction. Remove and overhaul valve body. Replace accumulator seals. Make sure all valves operate freely in bores and do not bind or stick. Make sure valve body screws are correctly tightened and separator plates are properly positioned.
6. Overdrive Unit Thrust Bearing Failure. Disassemble overdrive unit and replace thrust bearing (NO. 1 thrust bearing is between overdrive piston and clutch hub; NO. 2 thrust bearing is between the planetary gear and the direct clutch spring plate; NO. 3 thrust bearing is between overrunning clutch hub and output shaft).
7. O/D Check Valve/Bleed Orifice Failure. Check for function/secure orifice insert in O/D piston retainer.
DELAYED 3-4 UPSHIFT (SLOW TO ENGAGE)
2. Throttle Valve Cable Mis-adjusted. Adjust throttle valve cable.
3. Overdrive Clutch Pack Worn/Burnt. Remove unit and rebuild clutch pack.
4. TPS Faulty. Test with DRBŪ scan tool and replace as necessary
5. Overdrive Clutch Bleed Orifice Plugged. Disassemble transmission and replace orifice.
6. Overdrive Solenoid or Wiring Shorted/Open. Test solenoid and check wiring for loose/corroded connections or shorts/grounds. Replace solenoid if faulty and repair wiring if necessary.
7. Overdrive Excess Clearance. Remove unit. Measure end play and select proper spacer.
8. O/D Check Valve Missing or Stuck. Check for presence of check valve. Repair or replace as required
TORQUE CONVERTER LOCKS UP IN SECOND AND/OR THIRD GEAR
Lockup Solenoid, Relay or Wiring Shorted/Open. Test solenoid, relay and wiring for continuity, shorts or grounds. Replace solenoid and relay if faulty. Repair wiring and connectors as necessary.
HARSH 1-2, 2-3, 3-4 OR 3-2 SHIFTS
Lockup Solenoid Malfunction. Remove valve body and replace solenoid assembly.
NO START IN PARK OR NEUTRAL
1. Gearshift Linkage/Cable Mis-adjusted. Adjust linkage/cable.
2. Neutral Sense Wire Open/Cut. Check continuity with test lamp. Repair as required.
3. Park/Neutral Switch, or Transmission Range Sensor Faulty. Refer to service section for test and replacement procedure.
4. Park/Neutral Switch, or Transmission Range Sensor Connection Faulty. Connectors spread open. Repair.
5. Valve Body Manual Lever Assembly Bent/Worn/Broken. Inspect lever assembly and replace if damaged.
NO REVERSE (OR SLIPS IN REVERSE)
1. Direct Clutch Pack (front clutch) Worn. Disassemble unit and rebuild clutch pack.
2. Rear Band Mis-adjusted. Adjust band.
3. Front Clutch Malfunctioned/Burned. Air-pressure test clutch operation. Remove and rebuild if necessary.
4. Overdrive Thrust Bearing Failure. Disassemble geartrain and replace bearings.
5. Direct Clutch Spring Collapsed/Broken. Remove and disassemble unit. Check clutch position and replace spring.
OIL LEAKS.
1. Fluid Lines and Fittings Loose/Leaks/Damaged. Tighten fittings. If leaks persist, replace fittings and lines if necessary.
2. Fill Tube (where tube enters case) Leaks/Damaged. Replace tube seal. Inspect tube for cracks in fill tube.
3. Pressure Port Plug Loose Loose/Damaged. Tighten to correct torque. Replace plug or reseal if leak persists.
4. Pan Gasket Leaks. Tighten pan screws (150 in. lbs.). If leaks persist, replace gasket.
5. Valve Body Manual Lever Shaft Seal Leaks/Worn. Replace shaft seal.
6. Rear Bearing Access Plate Leaks. Replace gasket. Tighten screws.
7. Gasket Damaged or Bolts are Loose. Replace bolts or gasket or tighten both.
8. Adapter/Extension Gasket Damaged Leaks/Damaged. Replace gasket.
9. Park/Neutral Switch, or Transmission Range Sensor Leaks/Damaged. . Replace switch and gasket.
10. Converter Housing Area Leaks. Check for leaks at seal caused by worn seal or burr on converter hub (cutting seal), worn bushing, missing oil return, oil in front pump housing or hole plugged. Check for leaks past O-ring seal on pump or past pump-to-case bolts; pump housing porous, oil coming out vent due to overfill or leak past front band shaft access plug.
11. Pump Seal Leaks/Worn/Damaged. Replace seal.
12. Torque Converter Weld Leak/Cracked Hub. Replace converter.
13. Case Porosity Leaks. Replace case.
NOISY OPERATION IN FOURTH GEAR ONLY
1. Overdrive Clutch Discs, Plates or Snap Rings Damaged. Remove unit and rebuild clutch pack.
2. Overdrive Piston or Planetary Thrust Bearing Damaged. Remove and disassemble unit. Replace either thrust bearing if damaged.
3. Output Shaft Bearings Scored/Damaged. Remove and disassemble unit. Replace either bearing if damaged.
4. Planetary Gears Worn/Chipped. 4 Remove and overhaul overdrive unit.
5. Overdrive Unit Overrunning Clutch Rollers Worn/Scored. Remove and overhaul overdrive unit.
cms829 is offline
post #4 of 6 (permalink) Old 12-05-2014, 10:56 PM Thread Starter
Thanks guys...CMS that was one hell of a post.
Many issues involved here, all of which led to catastrophic failure. I just ordered a new upgraded trans for it (47RE). In wanting to be able to drive it the 3 miles from my place to my mechanic so he could do the swap, I dropped the pan and changed the filter and added approx six quarts of Amalie +4. In the bottom of the pan was part of the belt tensioner, a little wedge with a notch in it with a little ball socket on the thick end. Problem 1, nobody every serviced the tension. I think the pulsing was probably solenoid related and ultimately the clutches just burnt up. Got it the 3 miles I needed, had to cycle thru all of the gears to get it into drive, but it stayed there and didn't act too horrible. Looking forward to getting it back next week as borrowing trucks to haul live animals and using my wife's subaru to bring back the whole half's riding shotgun is getting old.
defdes is offline
post #5 of 6 (permalink) Old 12-20-2014, 02:31 PM Thread Starter
So, new tranny is in. I now have a flare 1-2 shift. It shifts into 2nd fine, then seems like it gets another signal immediately after to shift to 2nd again, flares 100 rpms then goes normally. This does not happen the first 1 or 2 shifts when cold, only after warm up.
Then, I was having some issue with 2-3 shuttling around at around 1500 rpms (35 mph) that seems to be gone now after adjusting the TV cable, I am curious now as to whether it should be downshifting to 2nd when it's not (again around 1500 rpms, 35 mph).
I am going to re check the throttle linkage, but any ideas about the 1-2 flare?
defdes is offline
post #6 of 6 (permalink) Old 01-31-2015, 07:41 PM Thread Starter
I read this post https://www.cumminsforum.com/forum/94...ormance-5.html
which was helpful but there is still one issue that I am chasing.When below 35mph in 3rd and when rpms are below 1400, I step on the gas slowly the rpms will increase by 100 or so and then drop to where they were or a bit lower. My line pressures are within spec for a stock trans, this trans is one of the "Road Ripper" types made for motors with up to 100 extra hp.
So it feels like the trans should drop down to second at such a low rpm going 30 mph. Should I increase the line pressure or just adjust the TV slack stop as noted in the above post, or both?
My mechanic tested the pressures and I don't have the exact numbers, from what I remember him saying they went from 70 at idle up to 170.
defdes is offline
