HUGE coolant leak - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 06-16-2010, 10:13 AM Thread Starter
stabler's Avatar
HUGE coolant leak
One day out of the blue I notice my truck is leaking coolant. It is coming from the lower coolant neck/junction on the passenger side of the block. I then proceeded to do the thing anyone would... buy a new gasket and replace the old one. To my surprise the truck leaked worse. I then tear it all the way down again this time being very careful to clean , sand mating surfaces, make sure its dry, and adding some gasket sealer/maker. I waited 2 days to make sure the gasket sealer would be nice and cured. Sure I had fixed the issue this time I fill it back up with coolant and start it up only to realize that it is now pouring coolant out of the same place...
WTF!! am I missing something.. is there a common issue i dont know about.. Anyone have this issue before? Any suggestions would be great..
98 3500 12v 4x4 ext cab 5spd
stabler is offline
post #2 of 22 (permalink) Old 06-16-2010, 05:55 PM
GeneralC's Avatar
im confused on where your referring to it leaking? is it the lower radiator hose ? or the radiator is cracked itself ?
Sold: 1991 W250 5 Speed metallic blue. 3200 gov spring, pump maxed, M&H M3 fuel pin, timing bump, dipricol gauges, 4 inch Diamond eye, s300 and 6X16s and airdog 150.18" moto metal 955's, dual-disk, coolertubz.
GeneralC is offline
post #3 of 22 (permalink) Old 06-17-2010, 12:35 AM
not sure I know where exactly you mean either, but could the coolant be coming out of the weep hole on the water pump and dripping off the part you mentioned?
'93 DRW X-Cab A518 Bone stock except for heater grid delete. No black smoke. 287K
93wuntun is offline
post #4 of 22 (permalink) Old 06-17-2010, 09:37 AM Thread Starter
stabler's Avatar
Its the neck/junction at the bottom below the alt... the tensioner is attached to it.. the same bracket is also used to attach air conditioning to.
its not the weep hole.. the coolant is literally pouring out.. makes no since to me.. the coolant is def come from behind the bracket for the tensoner and AC..
stabler is offline
post #5 of 22 (permalink) Old 06-17-2010, 12:15 PM
mrmoparwl's Avatar
stabler have the lower rad hose housing cleaned well and depending on the material its made of check it for a crack.
92 D250 Club Cab LE, I/C, BD converter, Banks 16cm turbine housing, 100hp sticks, minor mods.
91 W250 I/C, Getrag, pin turned 90deg 400000kms, headed for the RC chassis now!
mrmoparwl is offline
post #6 of 22 (permalink) Old 06-17-2010, 12:27 PM Thread Starter
stabler's Avatar
I did that... sanded the mateing surfaces, cleaned it, and put gasket sealer on it..
stabler is offline
post #7 of 22 (permalink) Old 06-18-2010, 06:56 PM
one of my trucks would leak there when cold but stop when it warmed up. took it apart and found the rubber seal that looked like a pice cut off a rubber hose. went to dodge with it ( i do not find my local dealer overly usefull) and they ordered what they thought it was. what came in want right so i cleaned everything and put gasket sealant on the old one and put it back together. it did the same thing for a week and then quit leaking. made no sence to me but i sold the motor before i took it apart again.
2012 ccsb Black Laramie Limited, Torn apart mess....
mike8061 is offline
post #8 of 22 (permalink) Old 06-20-2010, 08:20 PM Thread Starter
stabler's Avatar
Samething... it actually pours out of there now.
But only I have the correct rubber gasket and it still pours out of there..
stabler is offline
post #9 of 22 (permalink) Old 06-22-2010, 02:35 PM Thread Starter
stabler's Avatar
Anyone have any other ideas/suggestions?
stabler is offline
post #10 of 22 (permalink) Old 06-22-2010, 05:53 PM
cornman369's Avatar
oil cooler gasket? its really close by?
ive been watching this thread awhile, im stumped
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #11 of 22 (permalink) Old 06-22-2010, 07:31 PM
AKturbo's Avatar
I think I had the same problem a couple weeks ago. Just cut out the metal pipe + rubber hose and replaced the whole thing with a rubber hose and that fixed it.
89 W250. Built 47rh w/ 3.07s, Contagios 5x.014", VE pump mods, M&H spacer+to the head, DennyT stgII, 366 spring, 12mm Studs, 60# springs, HE351VGT, SteedSpeed, 3" crossover, 4"TBE, BHAF, Racor 500 filter, Holley Blue (modified), Isspro pyro/boost/drivepress/fuelpsi/trans temp
AKturbo is offline
post #12 of 22 (permalink) Old 06-23-2010, 09:51 AM Thread Starter
stabler's Avatar
no, Its the gasket between the AC bracket and the block..
stabler is offline
