Need help. Allison versus 47rh flywheel - Dodge Cummins Diesel Forum
post #1 of 2 (permalink) Old 08-24-2019, 03:34 PM Thread Starter
I'm changing from a Allison 545 from a bus to a 47rh. the 47rh flywheel wont fit over the crank snout. The diameter of the Allisons is 2.75 inches. The 47rh is 1 7/8. So, what now? I can give scenarios, but yall know a lot more than me. I'm in a time crunch, so I appreciate all advise. If one of you is out and about and has the time to talk, 580-235-2389. thanks.
oldskoolss is offline
post #2 of 2 (permalink) Old 08-24-2019, 09:54 PM
Is that the crank snout or the adaptor the Allison flex plate uses?
Cheers Steve
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, Aftermarket AFC spring, re-set injectors. tuning in progress
Blackduck59 is offline
