How common is the KDP? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 14 (permalink) Old 08-21-2019, 09:04 AM Thread Starter
sdeeter19555's Avatar
Well, since that is the case; I just ordered the TST KDP kit from Geno's; I'll tackle that whenever it comes in...
Sent from my SM-G950U using Tapatalk
sdeeter19555 is online now
post #14 of 14 (permalink) Old 08-21-2019, 06:22 PM Thread Starter
Ok, I've been researching this some...
Getting things apart, no surprises, nothing jumps out as difficult. Tabbing the pin, easy. Putting it together, nothing odd.
Where are the other bolts for the timing case (under the timing cover) that need loctite? Am I correct in assuming I need to spin the crank to access those bolts through the "access" holes in the timing gears?
And, because I watched it done both ways, is the crank seal indexed with the installer from the front or the back of the cover???? I see its punched to the back, installed from the back, but is it indexed from the front or the back? Or doesn't it make a difference?
