Low Fuel Pressure? - Page 4 - Dodge Cummins Diesel Forum
post #37 of 40 (permalink) Old 07-23-2019, 01:01 PM
sdeeter19555's Avatar
Originally Posted by 9297oldram View Post
I use a 33270 inline filter and so do a few others, you can use 3/8 steel brake line most places have it in 6' lengths.
What is the purpose of the inline filter when you have the screw-on downstream?
Sent from my SM-G950U using Tapatalk
sdeeter19555 is offline
post #38 of 40 (permalink) Old 07-23-2019, 02:35 PM
9297oldram's Avatar
To keep crap out of the LP so it'll last longer.
9297oldram is offline
post #39 of 40 (permalink) Old 07-23-2019, 10:58 PM Thread Starter
SweitzerWorks's Avatar
Originally Posted by myother4x4isaCJ7 View Post
Hard plastic line is factory, it should take the normal barbed fittings but in my experience the lines are aged to the point where they will crack if you try and push it onto a barbed fitting. Something to watch out for.
Yeah that's kind of the feeling I was getting. I suppose I'll just have to take a snip and see what happens. Heat gun might help?
1992 W250 LE, Getrag 5spd, Southbend Clutch, BD Pin/3200 Gov Spring, S300G, DAP 5x.011, 4" Straight Pipe
SweitzerWorks is offline
post #40 of 40 (permalink) Old 07-29-2019, 11:12 PM Thread Starter
Wrapped things up with the truck last weekend, been running great so far.
I replaced the shredded fuel pickup strainer with some stainless mesh and a band clamp. The HVLP works great, bled the system and it fired right up. It makes about 2psi more boost at the top end and definitely fuels way faster. Might have to crank that starwheel up a bit more if ya know what I mean ;D
A 0-15psi fuel pressure gauge is on it's way, and I think I'm just going to make my own banjo bolt for the fuel pressure "signal"
Thanks again ya'll!
