Running hot - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 06-11-2019, 07:01 PM Thread Starter
Running hot
Over the past year, I've replaced the radiator (NAPA made in Jordan), thermostat, hoses, and coolant 50/50 (plus one of the hypercooler additives). This summer the ambient temps have been 95F to 105F, and my coolant has been at times hitting 240F and up to 250F. The pressure is good and no coolant leaks. What should I be looking for or doing to deal with this.
mutantsubhuman is offline
post #2 of 11 (permalink) Old 06-11-2019, 07:24 PM
Moderator
9297oldram's Avatar
A bad clutch on the fan, not using a Cummins T-stat. Are you reading this from the factory gauge or a aftermarket one?
9297oldram is offline
post #3 of 11 (permalink) Old 06-11-2019, 07:26 PM Thread Starter
Both the dash and aftermarket (digital) gauge are high. How do you check the fan clutch? That has been on since the vehicle was new.
post #4 of 11 (permalink) Old 06-11-2019, 07:28 PM
Moderator
9297oldram's Avatar
If it's a original clutch good chance that's the problem, don't know how to check them. I've always used a electric fan on both of my trucks.
post #5 of 11 (permalink) Old 06-11-2019, 07:31 PM Thread Starter
Thanks for your input. I'll go ahead and replace the clutch to see if that solves the problem. I had electric dual fans on about 10 years ago but went back to the stock - don't remember why.
post #6 of 11 (permalink) Old 06-11-2019, 07:33 PM
Moderator
9297oldram's Avatar
If you heavy tow in hot weather sometimes the electric fans don't do the job.
post #7 of 11 (permalink) Old 06-11-2019, 07:59 PM
What sort of load is on it when running hot?
There is also the water pump to consider.
Are you blowing ang black exhaust smoke? Has any tuning been done to it?
Cheers Steve
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, Aftermarket AFC spring, re-set injectors. tuning in progress
Blackduck59 is offline
post #8 of 11 (permalink) Old 06-12-2019, 08:25 AM
foresterfields40's Avatar
When pulling a grade and the truck starts to heat up you should notice the fan clutch kick in because it’ll sound similar to a jet engine roar. If you don’t hear that then chances are that the fan clutch needs replaced as already mentioned
foresterfields40 is online now
post #9 of 11 (permalink) Old 06-12-2019, 08:29 AM
myother4x4isaCJ7's Avatar
Get the truck good and hot, then while itís running take a rolled up newspaper and touch the fan blades with it. If you can slow the fan down itís bad, if it just shreds the paper then the clutch is good.
myother4x4isaCJ7 is offline
post #10 of 11 (permalink) Old 06-12-2019, 01:56 PM Thread Starter
Replaced the clutch this morning. That solved the problem and also made the AC work much better. Thanks everyone.
The Following 2 Users Say Thank You to mutantsubhuman For This Useful Post:
9297oldram (06-12-2019), Blackduck59 (06-12-2019)
post #11 of 11 (permalink) Old 06-12-2019, 01:58 PM
Moderator
9297oldram's Avatar
Thanks for updating us and saying what fixed it.
