Non starter - Dodge Cummins Diesel Forum
post #1 of 37 (permalink) Old 04-07-2019, 09:33 AM Thread Starter
Non starter
Guys,
Just rebuild my 6BT and cant get it to fire unless I use ether to get it to fire first. Then it will idle OK but will not rev. When I removed an injector and cranked the engine the injector did not spurt fuel. Any ideas?
The motor all ran fine before it was rebuilt.
Kev
kevdachev is offline
post #2 of 37 (permalink) Old 04-07-2019, 01:03 PM
Edit: my mistake thought I was in the 24v section.
Hows you fuel pressure?
99 Ram 3500 SLT 4x4, P24v, ZF6-750, s362/475, 7x0.014, supporting mods.
marco610 is online now
post #3 of 37 (permalink) Old 04-07-2019, 04:59 PM
GAmes's Avatar
iTrader Score: 7 reviews
Which 6BT? VE pump or p-pump? I'm assuming you removed the injector pump for the rebuild. It has to be timed.
GAmes is offline
post #4 of 37 (permalink) Old 04-08-2019, 03:56 AM Thread Starter
Non starter
Guys,
Should have said before pump is a VE pump and it has been timed. Surely though if the timing were out the injector will still spurt but at the wrong time.
Kev
post #5 of 37 (permalink) Old 04-08-2019, 07:23 AM
Moderator
9297oldram's Avatar
Originally Posted by kevdachev View Post
Guys,
Kev
Have you verified that your FSS has power? Maybe just gut it to eliminate that possibility of it being the problem.
I've seen where a couple people have gotten a couple of there high pressure fuel lines in the wrong spots.
Did you get all the air manually bled out of the fuel system before trying to start it?
9297oldram is online now
post #6 of 37 (permalink) Old 04-08-2019, 10:38 AM Thread Starter
do you mean fuel shut-off solenoid cos that's working fine. All lines are in correct place. It will run when started on ether. Thinking its either timing or fuel pressure too low
post #7 of 37 (permalink) Old 04-08-2019, 10:46 AM
Moderator
9297oldram's Avatar
Did you do anything to the IP when it was off?
Have you checked to see if the small pin at the bottom of the AFC that rides on the fuel pin profile is stuck?
The stock LP puts out 3-5 psi what's yours?
post #8 of 37 (permalink) Old 04-08-2019, 11:25 AM
myother4x4isaCJ7's Avatar
Have you pulled the FSS and inspected it? If not you canít know if itís fine or not. The tip could have come off and is blocking fuel flow. You will still hear the normal click when power is applied but it wonít allow fuel to pass. And for the sake of your engine please stop using ether it is super hard on them.
myother4x4isaCJ7 is offline
post #9 of 37 (permalink) Old 04-08-2019, 11:26 AM
When the tip fell off my fss it did the same thing, Would be really hard to start and when it did it would only idle
post #10 of 37 (permalink) Old 04-08-2019, 12:04 PM
Moderator
9297oldram's Avatar
What he's saying ^^^^ gut it and see if it helps any in it starting. Doesn't cost anything to do it and will eliminate that as a possible problem.
post #11 of 37 (permalink) Old 04-08-2019, 01:29 PM Thread Starter
OK thanks for the advice so far. I will check everything that's been said and get back to you. Thanks again Kev
post #12 of 37 (permalink) Old 04-08-2019, 01:49 PM Thread Starter
Guys,
Just thinking if the end had come off the Fuel shutoff solenoid surely the engine would not run at all. Once started on ether the engine idles quite nicely.
Similar Threads
Actual starter failure, want parts... JTraik 94-98 Powertrain 6 01-17-2015 04:56 PM
starter wont crank fordtoy350 94-98 Powertrain 0 01-10-2015 10:37 AM
Starting trouble Fischer 89-93 Powertrain 13 03-26-2012 12:19 PM
Starter stuck ON, looking for clarification stylin7 94-98 Powertrain 6 08-16-2011 04:52 PM
Replaced starter, still cranks slow and a smoke question hammerhome 94-98 Powertrain 3 04-08-2011 08:43 AM
