92 12v overdrive issues - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 03-01-2019, 11:09 AM Thread Starter
So I have this truck for about two years now and I've been trying to fix my overdrive, Its a 92 D-250. I haven't yet adjusted my tps sensor. I bought 2 new O/D Solonoids and neither one of them fixed it. I recently just bought a tps delete kit off of DNR Customs and it also did not work. I've been reading about a OVERDRIVE LOCKUP SWITCH? Is the 46rh capable of having this wired up. I'm 17 and would really like some help!! And one other thing My speedometer and Message Center do not work anymore, one day driving they just turned off and haven't came back on sense. ANY HELP IS GREAT
9FiRsTgEn2 is offline
post #2 of 10 (permalink) Old 03-02-2019, 07:54 PM
Moderator
9297oldram's Avatar
That trans has no LU on it you'll have to get a 47 rh or re to have that.
Have you ever cleaned the grounds and both ends of the battery cables?
You could have a bad wire going to the OD solenoid.
9297oldram is offline
post #3 of 10 (permalink) Old 03-04-2019, 08:22 PM Thread Starter
I put a new O/D solenoid in it twice, I could be a bad connection..and what’s this LU your talking about and I got new battery clamps and a battery recently
post #4 of 10 (permalink) Old 03-04-2019, 08:41 PM
Moderator
9297oldram's Avatar
You put OVERDRIVE LOCKUP SWITCH so I was thinking of Torque converter lockup, so disregard the LU comment I made. Most just say overdrive switch so it made me think of the other.
How about the other ends of the battery cables are they clean? What about the engine to firewall ground strap is it clean?
post #5 of 10 (permalink) Old 03-11-2019, 07:30 AM
JState's Avatar
Your pcm is most likely dead. Read the sticky on how to decomputerize your truck. All you have to do for overdrive is to ground the circuit with a switch. Personally I have a headlight dimmer on the floor wired up for this.
Sent from my SM-J727V using Tapatalk
1994 K3500 Crew-Dually, Exhaust, HO water pump, Duramax fan
1991.5 W250 Pump Mods, Diamond Eye Exhaust, Old Kelderman air rides, Mishimoto Rad
1970 Chevy C/10 SWB FS, 4BT, TH400, US Gear OD, Pump mods
JState is offline
The Following User Says Thank You to JState For This Useful Post:
scout2000 (03-11-2019)
post #6 of 10 (permalink) Old 03-11-2019, 10:50 AM
There's a thread around here that discusses working around most of the issues that the PCM takes care of.
scout2000 is offline
post #7 of 10 (permalink) Old 03-13-2019, 11:01 AM Thread Starter
Okay I’ll look around
post #8 of 10 (permalink) Old 03-13-2019, 12:28 PM
Moderator
9297oldram's Avatar
I just noticed you said your speedometer doesn't work so that could be why you don't have OD. Your best fix for your OD would be a adjustable Hobbs switch, alot of info on that fix if you was to GOOGLE it.
post #9 of 10 (permalink) Old 04-20-2019, 05:49 PM Thread Starter
I had to throw a new Fuel Shut Off Solenoid I’m my pump, and ever sense I did that it won’t idle, I’ve ed with the idle screw, and the position of the Throttle lever and no matter what I do the old runs away.😤🙄
post #10 of 10 (permalink) Old 04-20-2019, 06:42 PM
Moderator
9297oldram's Avatar
Originally Posted by 9FiRsTgEn2 View Post
I had to throw a new Fuel Shut Off Solenoid Iím my pump, and ever sense I did that it wonít idle, Iíve ed with the idle screw, and the position of the Throttle lever and no matter what I do the old runs away.😤🙄
What runs away?
Similar Threads
DEF issues Poll CGCampbell07 2013+ General Discussion 430 06-11-2018 09:46 PM
2006 overdrive issues Jslap 3rd Gen. Powertrain 14 06-20-2016 10:55 AM
Overdrive and lockup controller(s) 'Mad Max' 89-93 Powertrain 6 03-05-2014 04:06 PM
Overdrive troubleshooting issues McKenna 89-93 Powertrain 5 03-10-2013 01:45 PM
Overdrive issues 12vChiaro 89-93 Powertrain 22 12-03-2012 06:04 AM
