Third gen turbocharger - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 07-13-2019, 06:50 PM Thread Starter
FirstGen169's Avatar
Good evening all! I’m in the process of doing a build on my first generation cummins and i was curious if anyone has ever used a turbo off of a third gen cummins? The turbo i am looking at from a buddy is the hc351 wc i believe and it’s got an electronic waste gate.. my questions are... is this a decent upgrade? How do i get rid of the waste gate? And what kinda power can be made with this particular charger? Currently my truck is bone stock until next weekend, i will then be maxing the VE pump out as much as i can and putting DDP stage 3 injectors in it with a 3,200 gov spring and fuel pin also from DDP.
FirstGen169 is offline
post #2 of 5 (permalink) Old 07-14-2019, 10:29 AM
Go into search using that turbo number, plenty of posts on here about using this turbo.
Cheers Steve
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, Aftermarket AFC spring, re-set injectors. tuning in progress
Blackduck59 is offline
post #3 of 5 (permalink) Old 07-14-2019, 03:02 PM
myother4x4isaCJ7's Avatar
If itís from a 04-07 third gen it should be a he351cw Iím running one on my truck and am very happy with it.
myother4x4isaCJ7 is online now
post #4 of 5 (permalink) Old 07-17-2019, 06:58 PM
Diesel Auto Power
iTrader Score: 21 reviews
Quick spool and more flow than stock. Good for about 350HP. needs new downpipe or adapter, clocking the turbo, blocking of the solenoid port, spring gate for use as new actuator, and intercooler boots/piping to make it work.
if the turbo is not free or close to it you may consider buying a new turbo as installation will be easier.
jkidd is online now
post #5 of 5 (permalink) Old 08-13-2019, 07:38 PM
Run one on my truck too. Love it.
'91.5 LE SCLB, HE351CW, 47RH, Swiss Cheese Airbox, THD Lift Pump, THD fuel pin, 366 Spring, 4" exhaust, THD long fuel screw, timing spacer, Pwr Stroke IC, 3" IC piping, Chevy Seats, LED lights.
JeepCJ5 is offline
