Compound turbos - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By jkidd
post #1 of 6 (permalink) Old 05-14-2019, 10:30 AM Thread Starter
Compound turbos
Hey everyone, new to the forum posting. So I have a 91 Non- intercooled VE. Have a Hx351 turbo, pod injectors, 60 lbs valve springs and my pump is maxed out is a DennyT Fuel pin and a 3200 governor spring. So I’m want to do some upgrades and I have a good handle on all that I want to do but compound turbos. I want to run compounds with My HX351 and Ht3b combo. But the it kinda blowing my mind I really don’t grasp how to properly tie them in and waste hate them. I’m a welder by trade so I’m not worried about making the piping. Can someone help me grasp this concept a little better. Like how to tie in the turbos and where my waste gates should be.
Tb4570 is offline
post #2 of 6 (permalink) Old 05-15-2019, 12:56 PM
Ducati M.
DMan1198's Avatar
You donít need to add any wastegates, just set the one on your little turbo to around 20psi to start with. If you havenít bought the ht3b yet Iíd get something that isnít 40 year old technology.
Routing is simple. Exhaust manifold goes into little turbo, pipe goes between little turbo outlet, and big turbo inlet. Big turbo outlet goes to tailpipe. On the intake filter mounts to big turbo inlet, pipe goes between big turbo outlet, and little turbo inlet. Little turbo outlet goes to engine.
ID:	847887   Click image for larger version
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram:
DMan1198 is offline
The Following User Says Thank You to DMan1198 For This Useful Post:
jkidd (05-21-2019)
post #3 of 6 (permalink) Old 05-21-2019, 10:21 AM
Diesel Auto Power
iTrader Score: 21 reviews
DMan1198 That is a nice set up!
93oneton likes this.
jkidd is offline
post #4 of 6 (permalink) Old 05-30-2019, 02:47 PM
93oneton's Avatar
Here is a pic of how mine is routed. Same idea just a different way to,position them
93oneton is offline
post #5 of 6 (permalink) Old 06-03-2019, 06:48 PM
Diesel Auto Power
Nice....
Easy to work with when you have easy access to everything!
jkidd is offline
post #6 of 6 (permalink) Old 06-03-2019, 07:33 PM
Ducati M.
DMan1198's Avatar
Ain’t that the truth. Last time I pulled my setup apart it took me about 30 minutes to pull everything but the downpipe out.
DMan1198 is offline
Similar Threads
compound turbos, which ones to get for my application. boomup73 3rd Gen. Performance Parts Discussion 48 02-06-2014 12:51 PM
HX35/HT60 compound turbos stangman95 94-98 Performance Parts Discussion 8 04-26-2012 06:47 PM
questions about compound turbos otisd85 94-98 Performance Parts Discussion 15 09-11-2011 03:10 PM
