injector nozzles - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 05-01-2009, 10:24 AM Thread Starter
gotacummins's Avatar
injector nozzles
How hard is it to excange injector nozzles? Do they do this for 1 gens? I see there is a group buy for nozzles in the sponsor section for around $250. It seems like a cheaper route to go that buying injectors?
[/B] 04F250 FX4 CC/12V/ZF6
SDX 5X14, HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring
gotacummins is offline
post #2 of 6 (permalink) Old 05-01-2009, 10:47 AM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
You would need to find out if they are aviable for a 1st gen. Our trucks use a different spray angle than a 2nd gen.
You would need to reset the pop pressures after a tip change. Here is a little reading on a pop tester.
How to build a diesel injector pop tester - PeachParts Mercedes ShopForum
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
post #3 of 6 (permalink) Old 05-01-2009, 01:16 PM Thread Starter
there some smart people out there! i guess its not worth the hassle i guess just buy the whole injector is easier
post #4 of 6 (permalink) Old 05-09-2009, 11:12 PM
DSTAD's Avatar
8.3 nozzles will fit. my buddy has them and the flat out pour out the fuel.
96 3500 2wd, ddp 2’s, 3kgsk, #10 plate. Hybrid over s475, bd full roller bearing trans, DiPricol gauges, bd torq loc and tow loc, Pac brake 4” inline, Aux trans cooler with fan, Firestone ride rite with on board air/control, DSS, Centramatics, Maghytec, DDP Boost.
DSTAD is offline
post #5 of 6 (permalink) Old 05-10-2009, 10:19 AM
Left out in the cold's Avatar
Any info on what the 1st gen pop pressure should be?
Left out in the cold is offline
post #6 of 6 (permalink) Old 05-10-2009, 10:36 AM
dnelson's Avatar
if i remember right it is 245 bar
92 3/4 ton 4x4 5 speed, modified.
2012 3/4 ton 4x4 6 speed manual, leveled on 35x20's, tt2, 4"tbe, egr mia
dnelson is offline
