abs light on 90' wont go out - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 10-23-2006, 10:06 AM Thread Starter
Southern california Chapter President
SB1tate's Avatar
I've replaced the master cylinder three times, and check the brakes, and still the light will not go out. system seems to work fine, how do I get this fixed?
90' 350 2wd, 5spd.
Southern California President
U.S. MARINES91'/ARMY01'/NAVY Special Boat unit
DESERT STORM, IRAQ AND AFGHANISTAN VET
2006 MEGACAB LONGBED CONVERSION 4X4 2500 CTD BANKS BIG HOSS BUNDLE KIT
LONGBED CONVERSION
SB1tate is offline
post #2 of 4 (permalink) Old 10-26-2006, 12:47 PM
Paccool's Avatar
Seabee, do the brakes seem to fade away when sitting at a light with your foot on the brakes? If so, could be a leaking brake booster causing the light to stay on.
Some guys have reported a bad connection at the plug on the rear end where the tone ring sensor plugs into the harness. Take apart, clean, and reinstall to see if it helps any.
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HDcrew cab 4x4, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, Banks intake, ported turbo mouthpiece. Predator programmer, Autometer EGT and boost gauges.
Paccool is offline
post #3 of 4 (permalink) Old 11-03-2006, 05:21 PM
Unplug the abs control module behind the glovebox. No more abs light.
bgilbert is offline
post #4 of 4 (permalink) Old 12-15-2006, 06:03 AM
The ABS sensor on the D250 sits on top of the differential, relatively cheap and fixed my problem. Of course I'd already done everything else before I found it: clean all the connectors, pack them with dielectric grease <there is one over the left rear too>, bleed / flush the hydraulic system starting with furtherest away from master. Check the adjustment on the brake switch. All good stuff, turned out to be the sensor; tried cleaning it first etc. etc. Hope it's that simple for you.
D
D
Stock early’93 D250, 5.9, 4Sp.Auto, RWAL,Ext.Cab+LwheelBase,VEPump
dhendry is offline
