1993 12V Ramcharger Conversion - Dodge Cummins Diesel Forum
 1Likes
post #1 of 178 (permalink) Old 02-22-2013, 02:31 AM Thread Starter
K2Truck1's Avatar
Well guys a lot has happened in the last few months... I have a thread going on the perf parts page for my race truck...that project has been parked for the next year. Plans are to build a new engine ( 12V short block-24V head modded-P-Pump 1000HP ) for 2014 season. Planning a few more tricks for the truck chassis too.
Anyway....with that one parked I really started twitching to start another project...I have been dreaming about a 12V Ramcharger Street Sleeper for a couple of years now. Last year I found a super clean 93 Ramcharger full load write off and a solid 91.5 W250 donor. Both trucks are 2WD Auto's. I started stripping and documenting both last year. I ended up moving shops, having a few changes in plans and welcomed a new mouth to feed last night! So things have slowed down on the project but haven't stopped.
I stripped both trucks last year for the damage on the Charger and pulled the 12V from the donor. I was a little concerned about the commonality of the parts and conversion issues. I wanted to post this thread as I hope you guys enjoy the final outcome of my dream project, but also get to see how easy this can be with these trucks with close model years.
So the engine and trans are in and test fired.
So far this swap has been a bolt in deal! I am amazed at how common these trucks are with such different backgrounds and body types. My end goal is a fun little 400hp street sleeper that is de-badged...clean looking...lo pro stance....family fun cruiser that people will look at and go...." that 318 sounds a little loud??" I will post pics of the project as I go and hopefully at the end of it all it turns out like my mental picture. I definitely welcome comments and criticisms on this guys as some of you have followed my race truck build and have created such a positive response.
Livin the dream....MOST days a nightmare! 98.5TDC...Heading for 800hp summer play/race toy..1980 1/2 ton 2WD race truck...heading for low 10's with new build..1990 250,4WD,12V Shop truck...loud and proud..03 3500 quad longbox..heading for 600hp tow rig...00 1/2 ton gasser parts runner--doesn't need 1/2 hour to warm up..93 2WD Ramcharger 5.9 street killer project under construction
K2Truck1 is offline
post #2 of 178 (permalink) Old 02-23-2013, 01:13 AM Thread Starter
K2Truck1's Avatar
Some more pics...
K2Truck1 is offline
post #3 of 178 (permalink) Old 02-23-2013, 08:14 AM
Bschwarzli's Avatar
Looks great. Well done!
1980 Dodge W350 Crew Cab Dually, 97 12V, HX35/HT3B, 24 speed, Air ride, SRT8 interior, D80, Np205, D60F
1990 W250 24 spd, not close to stock, Super HX40, ASA intake - 2008 2500 Mega 6.7 68RFE
Bschwarzli is offline
post #4 of 178 (permalink) Old 02-23-2013, 09:29 AM
Looks like a fun project can't wait to see it done!
1992 W250 aka Big Ugly 4" DE exhaust Ice Box Intake CAI low presure piston lift pump THD fuel pin 1992 Jeep Renegade 1994 Jeep Wrangler Sahara Project Bean maybe Diesel powered soon!
1992 Renegade is offline
post #5 of 178 (permalink) Old 02-23-2013, 09:37 AM
Broke Down's Avatar
iTrader Score: 13 reviews
Broke Down is offline
post #6 of 178 (permalink) Old 02-23-2013, 11:36 AM
Left out in the cold's Avatar
You might want to use the suspension out of the pickup too. The 1/2 ton axle won't take the torque and the front springs won't take the weight.
Left out in the cold is offline
post #7 of 178 (permalink) Old 02-23-2013, 11:06 PM Thread Starter
K2Truck1's Avatar
Thanks guys! I actually want to run the 1/2 ton suspension and diff. It's got an open Corporate 9 1/4 with 3.23 gears. I run full 1/2 ton suspension in my race truck with an 8 3/4 with 3.23's and that combo is handling over 700 hp with 20 psi boosted launches quite well. I will add a locker to help with traction. I have an idea it will take it and ride like a caddy. If not and things start to give grief I still have the front end out of the donor. So far it has a near stock stance. It's part of my think outside the box and what the hell try it mentality!!
K2Truck1 is offline
post #8 of 178 (permalink) Old 02-23-2013, 11:16 PM
mountianman69's Avatar
I wish they made a 4 door ram charger.... I need a family vehicle
(Built by The Pit Stop) 2001 QCSB 4x4 35" Pro comps TWINS superB over S475 with CPP 7X12 SACs with lift Quad 4K Phantom2 guages AIRDOG 150(THE GOOD FITTINGS NOT THE CRAP ONES) Valair 800hp ceramic DD billet input shaft Hamilton push rods and Hamilton springs Stainless diesel twin kit (fits perfectly!!) stainless diesel adjustable waste gate And thanks to Optima 2 Brand spanking new Red tops as a truck warming gift!
Originally Posted by DieselDon16 View Post
Im not gonna be a Bachleor silly, Im gonna marry you!!
"Im Forever yoouuurrrsss, Faithfully.........Nick"
mountianman69 is offline
post #9 of 178 (permalink) Old 02-23-2013, 11:17 PM Thread Starter
K2Truck1's Avatar
So far the engine bolted into the factory mounts and location. The trans mounted up to the factory 318 x-member which I laid beside the 3/4 ton unit and they are identical, the donor wiring harness plugged right into the charger firewall plug and engine started on the key, the trans linkage bolted up, the 318 driveshaft plugged right into the donor trans and mounted back up the diff perfectly, the trans and engine clear the cab, starter clears, and I bought a 4 inch 1st gen downpipe which fits perfectly,and so far it has been like this---plug and play. See how far the assembly goes before any modding is required......
K2Truck1 is offline
The Following User Says Thank You to K2Truck1 For This Useful Post:
flyhigh (07-12-2013)
post #10 of 178 (permalink) Old 02-23-2013, 11:22 PM Thread Starter
K2Truck1's Avatar
Like this one??
http://farm4.static.flickr.com/3288/...8933b8cc23.jpg
http://farm4.static.flickr.com/3140/...b15bca248c.jpg
https://encrypted-tbn3.gstatic.com/i...2zme2yDz8YYbqv
If I remember correctly this one is Cummins powered too.
K2Truck1 is offline
post #11 of 178 (permalink) Old 02-23-2013, 11:27 PM
Yeah I have a suburban that I want to swap a 12v in ..
The Following User Says Thank You to mountianman69 For This Useful Post:
coma700 (07-11-2013)
post #12 of 178 (permalink) Old 02-24-2013, 01:06 AM Thread Starter
K2Truck1's Avatar
I've got a really good friend here that wants to do the same...I told him to follow along the Doomsday Diesel that DP magazine is building....and when he gets ready I will give him a hand....he started out trying to put a 12V in an old Cherokee but his shop burnt down and lost drive on the project. So a burban is up next for him
K2Truck1 is offline
