Can the oil cooler be cleaned? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-08-2006, 04:39 PM Thread Starter
1990 Dodge Cummins 5.9 (6BT engine)
Can the oil cooler be cleaned or does this part have to be replaced?
I'm concerned about oil pressure and oil temperature.
Aloha from Kona, Hawaii. Captain Dean Towle
1991.5 Dodge Ram W250 CTD w/IC 4x4 5-speed Hummer wheels & tires
Captain Dean is offline
post #2 of 7 (permalink) Old 04-09-2006, 12:45 PM
Dean, my understanding is that the oil cooler should not need to be cleaned. It will be cleaned during normal cooling system maintainence. The oil side will be cleaned whenever you change the oil. Are you having some problems with oil temps? The cooler should also have enough flow that you should not need to worry about the volume. The only real problem I have read with the oil cooler is they can and sometimes do spring a leak. If that happens then the radiator will fill with oil.
Tom
Tom05 is offline
post #3 of 7 (permalink) Old 04-09-2006, 12:54 PM
Monster Truck's Avatar
if you want to clean it then get oitl system cleaner and run it through for like 20 minutes then change your oil
94 Single Cab Custom Flat bed, Loaded, Auto,3.55s, straight 3.5'' pipe, custom fuel plate AFC all the way forward, Intake, 250k, New build lots to be done.
Monster Truck is offline
post #4 of 7 (permalink) Old 04-11-2006, 12:54 AM
monter truck,
what is this oitl? never heard of it.
bob
one_ton is offline
post #5 of 7 (permalink) Old 04-15-2006, 07:49 PM
Jakey's'01H.O.'s Avatar
lol he meant to say oil hehehe
'01 ETH/MONSTER VP. 835/1698 and a valve seat visited cyl 4...build in progress.
Jakey's'01H.O. is offline
post #6 of 7 (permalink) Old 02-19-2007, 11:27 AM
5.9fan's Avatar
Where is the oil cooler?
2014 CCLB 4x4 Tradesman. 5th wheel prep, upfitter switches, LSD, plow prep, on board air, amp bedstep
Its quiet... too quiet...
5.9fan is offline
post #7 of 7 (permalink) Old 02-19-2007, 12:50 PM Thread Starter
The oil cooler is located behind or underneath the oil filter. If you remove the oil filter you will be able to see the cooler. It is a long narrow unit that extends from the top of the oil filter (behind the filter mount) to just above the motor mount. It fits into a recess in the engine block.
