What did you do to your 1st gen truck today? - Page 1236 - Dodge Cummins Diesel Forum
 1006Likes
post #14821 of 14948 (permalink) Old 07-15-2019, 11:00 AM
DenniferAniston's Avatar
Originally Posted by myother4x4isaCJ7 View Post
Take the chance to upgrade to chevy one ton wheel cylinders or at the very least one ton first gen ones (Chevy ones are better) also put in 3” shoes. If your current ones are covered in brake fluid they will never be the same.
What does it take to swap over to the Chevy wheel cylinders and 3” pads ? Pretty sure it’s all stock back there.
1990 w250 standard cab long bed 4x4 5 speed 4” straight pipe exhaust
DenniferAniston is offline
post #14822 of 14948 (permalink) Old 07-15-2019, 11:16 AM
9297oldram's Avatar
The wheel cyls just bolt in and you should already have the 3" pads. All the Dana 70's i've had were the 3".
9297oldram is offline
post #14823 of 14948 (permalink) Old 07-15-2019, 11:57 AM
What year of Chevy wheel cylinder ?
post #14824 of 14948 (permalink) Old 07-15-2019, 12:00 PM
9297oldram's Avatar
Here's the PN 37337.
DenniferAniston likes this.
post #14825 of 14948 (permalink) Old 07-15-2019, 03:59 PM
myother4x4isaCJ7's Avatar
Both of my first gens had 2.5 shoes. (2.5 is factory for 3/4 ton) 3” is a direct replacement even used the same drums.... no idea why they ever did that
myother4x4isaCJ7 is online now
post #14826 of 14948 (permalink) Old 07-16-2019, 08:01 AM
Brakes
Did they offer 3” shoes with a tow package or something? I could totally see the mind set of. Set it up for 3 “ but make them pay extra for it at some board meeting.
post #14827 of 14948 (permalink) Old 07-16-2019, 04:38 PM
Could be right there. I noticed a huge improvement going to 3” but even more with the 3.5” shoes in my second gen axle that’s in there now. It also has Chevy 1 Ton cylinders.
post #14828 of 14948 (permalink) Old 07-17-2019, 10:52 AM
That sounds like you have all the stopping power. I had been enjoying the new found stopping power of properly working brakes. I had that brake booster leaking and getting slowly worse the whole time I have owned the truck. Just thought it was how they were supposed to feel. Once they got so bad they didn’t work I figured it out. Haha Ordered up those wheel cylinders and 3” shoes. Now if I can just get off work before they close so I can pick them up.
post #14829 of 14948 (permalink) Old 07-19-2019, 07:02 PM
DieselMachine's Avatar
Added a set of Bilstein 5100 shocks to the w250 today. No test drive yet but the old shocks were in horrible shape, incredibly rusted and provided very little dampening. Will be sure to report back after I’ve got a few miles on it.
2013 3500 Laramie QCLB SRW Aisin 4.10 4" BDS 285 Toyo M608z Vision 19.5s Carli track bar Fox 2.0s
1993 W250 HE351W w/ 4" TBE Gov Spring THD Fuel Pin BHAF
DieselMachine is offline
post #14830 of 14948 (permalink) Old 07-20-2019, 02:57 PM
Baxter's Avatar
Bought me another one yesterday. Not too bad for $1K. Pretty rough, something's going on with the front axle. Runs great though! Have big plans for it...
Google Mechanic Extraordinaire
92 W250, Automagic, 4" lift, 37's, BHAF, 4" TBE, 175hp P-pump, 16.5*, DDP fuel plate, DAP 5X.014s, GSK(?), 60lb. ex. springs, HE351CW, P/S I/C.
Baxter is offline
post #14831 of 14948 (permalink) Old 07-20-2019, 05:09 PM
thrashingcows's Avatar
Got a bunch of stuff done on the truck last night.
I was going to rebuild the steering coupler since it was getting bad and I had over 45* movement in the steering wheel before it would affect the tires, but I was out looking at the parts truck and it had a steering shaft with a large U-joint so decided to clean it up and use that one instead. I also installed the new drag link.
Also since it's been 5 years and over 100K km's I wanted to change my tranny fluid and filter. I run one of those string filters that sit inside a housing on the RH PTO location....works very well.
A comment by Oliver stuck in my head that he runs the same fluid in the NV4500 and NP205...which makes some sense to me. So decide to also drain my transfer case and move the older Castrol Syntorque from the tranny into the TC.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #14832 of 14948 (permalink) Old 07-22-2019, 01:59 PM
Nadir Point's Avatar
Those U-joint shaft upgrades are the only way to go with 1st Gen steering coupler repair. It's the difference between doing it for the last time or doing it again after another 50k or whatever.
thrashingcows likes this.
1stGen: (1) (2) (3) (4) Commonrail: (2)
Nadir Point is offline
