Differential question - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By 702 3500
post #1 of 7 (permalink) Old 02-08-2020, 03:38 PM Thread Starter
Hello everyone so I have a 93w350 I want to change the diff fluid I will attach a pic of the identification tag I dont think it's a LSD so will it by ok putting a 80w90 gear oil that contains a friction modifier. also if I run 80w90 with the modifier already added to the np205 will that be ok as well I plan on using redline products
702 3500 is offline
post #2 of 7 (permalink) Old 02-08-2020, 05:31 PM
thrashingcows's Avatar
80W90 is fine, and the NP205 will run on pretty much anything, GM ran them with ATF.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #3 of 7 (permalink) Old 02-08-2020, 06:26 PM Thread Starter
Ok thanks I no the viscosity of the oils are ok but what I'm really wanting to no is the gear oil with friction modifiers already blended in from the factory are they ok to use on a diff that doesnt have a LSD or the np205. Or does the friction modifiers make it to slippery
702 3500 is offline
post #4 of 7 (permalink) Old 02-08-2020, 08:08 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
You’ll be fine with the modifier. Jack up the rear end and spin over the tires, if they both spin the same way, you’ve got posi
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #5 of 7 (permalink) Old 02-08-2020, 08:34 PM Thread Starter
Thanks bro you've answered a bunch of my questions in the past appreciate you to the [email protected]
98whitelightnin likes this.
702 3500 is offline
post #6 of 7 (permalink) Old 02-14-2020, 10:08 PM
sdeeter19555's Avatar
Friction modifier only prevents LSD clutches from chattering, you can use gear oil with friction modifier in any non-LSD application without worry.
If the truck has an LSD, and it chatters after changing fluids, you may simply need to add more modifier (available at any parts house)...I had both a D70 and a 11.5AAM that chattered on any fluid used, they both needed additional modifier.
Sent from my SM-G950U using Tapatalk
sdeeter19555 is offline
post #7 of 7 (permalink) Old 02-15-2020, 12:13 AM Thread Starter
Thank you sir
702 3500 is offline
