89 w250 rear leaf springs - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 11-18-2019, 03:12 PM Thread Starter
I'm in the process of doing a complete frame off on my truck. And I'm trying to decide to buy new rear leafs or do a re fresh on them. The truck has a 4 inch lift , there are 8 springs total in the rear pack, some of the c clips are gone. The springs themselves look ok. No sagging, I've thought about doing the spring tip inserts. And a good cleaning, sanding and caling it good. But also thought about just getting new ones.
Also you can see from the picture, the air ride . Shouldn't it be completely compressed? There is zero air in it now.
ID:	860917   Click image for larger version
MELVIN HUGH is offline
post #2 of 17 (permalink) Old 11-18-2019, 03:37 PM
Kmehr's Avatar
there's not a ton of give in those stock springs, I wouldn't be surprised if that is how they sat empty with no weight at all on them.
For springs, those look like they have plenty of arch left to them so I don't think they look worn out. If you are doing a restoration and want to make an improvement, I highly highly recommend doing the 64in chevy spring swap. It removes the lift block and gives about 4 in lift. It will DRAMATICALLY improve the ride of your truck, and if you do a little fab work, probably cost less than a new set of stock springs.
Jungle Jim over on ramchargercentral.com actually makes a kit for it.
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is online now
post #3 of 17 (permalink) Old 11-18-2019, 04:13 PM Thread Starter
Yes, they are stiff, any idea about the air lift.
post #4 of 17 (permalink) Old 11-18-2019, 08:18 PM
sdeeter19555's Avatar
No, the airbags will be almost full length (even without air) with no load as the springs are holding the weight...they are only meant to assist, not carry all the weight.
Sent from my SM-G950U using Tapatalk
sdeeter19555 is offline
post #5 of 17 (permalink) Old 11-18-2019, 08:55 PM Thread Starter
Here is another picture, of the leaf springs, the 1 c clamp on the other end is just wrapped around the 1st , 4 springs, on the shackle end there is none. And some separation is happening. Should i just get another c clamp for this end?
ID:	860947   Click image for larger version
post #6 of 17 (permalink) Old 11-18-2019, 09:38 PM
Someone has combined two packs into one...
post #7 of 17 (permalink) Old 11-18-2019, 10:53 PM Thread Starter
Why do you say that? Stock I believe they were a 7-1 pack
post #8 of 17 (permalink) Old 11-18-2019, 11:06 PM
Kmehr's Avatar
Combining leafs would be the worst! Thing wouldn’t flex!
Kmehr is online now
post #9 of 17 (permalink) Old 11-19-2019, 08:49 PM
Considering the airbags and all the extra leaves, I'd be curious how the axle housing looks.
That truck was hauling serious weight, most certainly abused.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #10 of 17 (permalink) Old 11-19-2019, 08:51 PM
The leaves being equal length in pairs, the missing spring clamps...
Factory never were stacked like that...someone has taken another set of springs and stacked the leaves for more capacity. Mine has Helwigs on it and rides like a brick, I could imagine that one is similar.
post #11 of 17 (permalink) Old 11-19-2019, 08:52 PM
Yep...mine was similar, was used to haul campers.
post #12 of 17 (permalink) Old 11-19-2019, 08:54 PM Thread Starter
I believe the 4 inch lift , has a extra leaf in there for the rear. As far as the leaf pack , someone correct me if I'm wrong, but stock the w250s had 8 leaf springs.
