Rebuilt Steering Gearbox Recommendation? - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By justinfonder
post #1 of 9 (permalink) Old 04-12-2019, 02:43 PM Thread Starter
For a 93 W250, Cummins, auto trans.
Saw a new drip under the front. Found the steering gearbox housing is cracked.
Genos does not have have them. Rock Auto, Advance Auto and others sell Cardone and some other brands of rebuilt units.
Is there enough experience out there to recommend one brand over the other?
Thanks
Jim
NMC_EXP is offline
post #2 of 9 (permalink) Old 04-12-2019, 04:27 PM
justinfonder's Avatar
Redhead or bluetop. Canít go wrong with either
1992 Renegade likes this.
justinfonder is offline
The Following User Says Thank You to justinfonder For This Useful Post:
NMC_EXP (04-12-2019)
post #3 of 9 (permalink) Old 04-12-2019, 05:17 PM
^this. Unless you want to replace it again in another year or two.
ManBearPig is offline
The Following User Says Thank You to ManBearPig For This Useful Post:
post #4 of 9 (permalink) Old 04-12-2019, 06:58 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
BlueTop is about $80 cheaper than RedHead. I just put a BT on my 98 and would do it again
1998 12v, 4x4, Club Cab, Carli, Thuren, Mostly Stock
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
The Following User Says Thank You to 98whitelightnin For This Useful Post:
NMC_EXP (04-13-2019)
post #5 of 9 (permalink) Old 04-12-2019, 07:19 PM
thrashingcows's Avatar
I have been running a cheap reman unit I got off E-bay for close to 10 years now. Only issue I have had with it was the input seal started leaking about 3-4 years ago, installed a new seal and been performing flawlessly since.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 350K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
The Following User Says Thank You to thrashingcows For This Useful Post:
post #6 of 9 (permalink) Old 04-14-2019, 01:33 PM
I just installed bluetop but haven't even put oil in it yet. Hoping to get that done today after server updates at work.
'91.5 LE SCLB, HE351CW, 47RH, Swiss Cheese Airbox, THD Lift Pump, THD fuel pin, 366 Spring, 4" exhaust, THD long fuel screw, timing spacer, Pwr Stroke IC, 3" IC piping, Chevy Seats, LED lights.
JeepCJ5 is offline
post #7 of 9 (permalink) Old 04-15-2019, 09:05 PM
u2slow's Avatar
A non-leaking box off a 2wd gas truck works just like new.
93 W250 Club 6BTA |5spd |60/80/3.54/Lockright |4" lift |315/75R16 |HX35 |5x.012s |BD pin & gov spring
84 Ramcharger (project) 6BT |5spd |WH1C| D70/3.07 ...plus a few other 75-93 D/W trucks
u2slow is offline
post #8 of 9 (permalink) Old 04-15-2019, 09:29 PM
I bought a NEW one from Prosteer at Autozone 5 years ago for $160 for my 99. Been great. Don't remember if it was lifetime warranty, maybe.
bigfish95971 is offline
post #9 of 9 (permalink) Old 04-15-2019, 10:58 PM
Exactly....My box was originally bought for my crewcab when it was 2wd, then after converting to 4wd it just continued it's service in the new capacity....as mentioned been working great this whole time.
Similar Threads
Rebuilt steering pump with new seals increased oil leak boone003 98.5-02 Non-Powertrain 5 05-18-2016 10:16 PM
Another steering gearbox question csnow 2010-2012 General Discussion 1 07-05-2015 09:26 AM
Pure Performance Ultimate HD Steering System Dodge Ram DieselPowerProducts Diesel Power Products 2 02-05-2014 07:45 PM
Which is the best steering gear? 1000EE-Monarch 98.5-02 Non-Powertrain 8 05-08-2011 01:51 PM
Has anyone ever rebuilt their gearbox? Jasonbailey1976 89-93 Non-Powertrain 1 05-02-2011 09:35 AM
