Buying "Tricks" - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Blackduck59
post #1 of 7 (permalink) Old 04-08-2019, 12:23 AM Thread Starter
sherwood0150's Avatar
Buying "Tricks"
I sold my 1st gen about a year ago but thinking of getting another (Love those trucks!!). One potential buyer pulled oil filler cap off and felt for pressure/blowby then put his ear to filler to listen for "squeaks" he said that would be caused by main bearing. First I've heard of those "tricks". Anyone know of any good buying "tricks" to test out motor, trans,...?
[SOLD] 1993 W250 5sp, M&H fuel pin, 366 spring, timing spacer, 4" Diamond Eye exhaust, 2 1/2" Alcan Leveling Springs, Borgenson steering shaft, redhead steering box, 100hp injectors, 16cm turbo housing, gauges...
sherwood0150 is offline
post #2 of 7 (permalink) Old 04-09-2019, 05:39 AM
Hope his ear was close enough to get a bit of lube to remove the squeaks from his head. BS!
bbosi likes this.
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, tuning in progress
Blackduck59 is offline
post #3 of 7 (permalink) Old 04-09-2019, 09:09 AM
myother4x4isaCJ7's Avatar
Not total bs, it the bearing is going out in the vacuum pump Iíve heard it squeak out of the tube but silent when itís closed. As for hearing main bearings...... if theyíre bad enough to squeak your gunna hear noises with the cap on or off that part is 100 percent bs.
myother4x4isaCJ7 is offline
The Following User Says Thank You to myother4x4isaCJ7 For This Useful Post:
sherwood0150 (04-09-2019)
post #4 of 7 (permalink) Old 04-09-2019, 01:42 PM
u2slow's Avatar
FWIW, this one truck of mine has an interesting noise coming from the oil filler. I've swapped the vacuum pump to the newer style, and the noise is unchanged.
93 W250 Club 6BTA |5spd |60/80/3.54/Lockright |4" lift |315/75R16 |HX35 |5x.012s |BD pin & gov spring
84 Ramcharger (project) 6BT |5spd |WH1C| D70/3.07 ...plus a few other 75-93 D/W trucks
u2slow is online now
post #5 of 7 (permalink) Old 04-09-2019, 06:03 PM
https://www.youtube.com/watch?v=WPPxoxg4xks
Interesting..... maybe the kdp fell out? It sounds exactly like my friends truck when it lunched the bearing in the vac pump. Noise went away with upgrading to the new style vane pump.
post #6 of 7 (permalink) Old 04-17-2019, 01:19 PM
avvblanc01's Avatar
About the only thing you can check for at the oil fill cap is blow by... haha
2006 2500 qcsb 4x4: auto, yukon hubs, Fass, 2mic Cat/baldwin 5mic FWS, 20" Trail Ready wheels & 37's, Edge insight, custom retroshop, heads/tails, Carli Dominator, Amp steps, Smarty JR 1993 D350 5spd, HID projectors, 4in TBE
avvblanc01 is offline
post #7 of 7 (permalink) Old 04-17-2019, 01:38 PM
Best "trick" I know is a $10 mechanics stethoscope. Works better than the old screwdriver to the ear trick.
1995 3500; pacbrake exhaust flange, 4" exhaust; turbo booster elbow; pan-off trans kit with towing valve body and deep alum pan; alum (add fluid) rear end cover. All factory extras except leather.
YogiBayer is offline
Similar Threads
Buying built or stock Fireoutguy 2010-2012 General Discussion 36 03-25-2017 11:41 AM
Buying my first Cummins -- Advice? Gunner512 98.5-02 Powertrain 85 10-04-2016 11:37 AM
trading/selling my 04, buying a 12 or 24 valve questions Sucka. 94-98 Powertrain 5 12-03-2011 10:14 PM
New Truck Buying Help Needed! DereksDodge General Diesel Discussion 0 09-11-2011 09:16 AM
Buying a new 2nd gen. but first a few ??'s... DereksDodge 98.5-02 Non-Powertrain 10 09-10-2011 03:10 PM
