Nv5600 swap - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 03-12-2019, 09:06 PM Thread Starter
Nv5600 swap
I'm planning to start my crew cab build pretty soon, going to run an nv5600 4wd and wanted some input on fitment. I would like to do minimal modifications to the tunnel and am wondering if I could make a custom 1 -2 inch body lift instead. Want to go with as little lift as possible to get the clearance needed.
jr90 is offline
post #2 of 10 (permalink) Old 03-12-2019, 09:54 PM
thrashingcows's Avatar
Have you searched the archives?? There is plenty of info out there, on this site and many of the other 1st gen forums, or just a google search away. Grab some snacks, and your favorite beverage and sit down for a few hours of reading.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #3 of 10 (permalink) Old 03-12-2019, 10:34 PM Thread Starter
I have searched but may not be using the right terms. All I can find are "will it work" haven't been able to find many completions.
jr90 is offline
post #4 of 10 (permalink) Old 03-13-2019, 01:03 PM
https://www.cumminsforum.com/forum/8...lots-pics.html
Either this thread or one of his others details an NV5600 swap extremely well. You are on your own for finding it.
1993 W250, G-360 manual completely stock.
Shelby/Dakota is offline
post #5 of 10 (permalink) Old 03-13-2019, 02:05 PM Thread Starter
I have read that thread a couple of times and he did some modifications to the tunnel which is why I was wondering if the small body lift would eliminate the need for that. I found another thread and they only mention cutting the shifter hole so it may work. Mainly just wanted opinions on if the body lift would be a good solution or not.
jr90 is offline
post #6 of 10 (permalink) Old 03-13-2019, 03:13 PM
u2slow's Avatar
If your crewcab build is happening on any non-crewcab frame... anything you add in the way of a body lift will reduce the amount you need to cut/channel the rear cab floor.
I plan to do 1-2" body lift just for improving working clearances under the truck. Cummins powertrain makes everything a tight fit. A flatbed doesn't care about body lines matching up.
93 W250 Club 6BTA |5spd |60/80/3.54/Lockright |4" lift |315/75R16 |HX35 |5x.012s |BD pin & gov spring
90 D250 6BT |5spd |D60/3.54/Lockright
u2slow is offline
post #7 of 10 (permalink) Old 03-19-2019, 01:46 PM
Bschwarzli's Avatar
You can do it through a body lift. But then things like the clutch hydraulics will become too short. So go just enough and no more. In the case of my crew, I have a 1" lift and still had some tunnel to cut. The 1990 had no body lift and had a fair bit of tunnel cut.
Hope that helps!
Robert
1980 Dodge W350 Crew Cab Dually, 97 12V, HX35/HT3B, 24 speed, Air ride, SRT8 interior, D80, Np205, D60F
1990 W250 24 spd, not close to stock, Super HX40, ASA intake - 2008 2500 Mega 6.7 68RFE
Bschwarzli is offline
post #8 of 10 (permalink) Old 03-19-2019, 03:38 PM Thread Starter
No flatbed for this one. I am doing a body swap but its onto a factory 4wd crew. That does help a lot. Did you just use a universal lift or custom.
jr90 is offline
post #9 of 10 (permalink) Old 03-19-2019, 04:19 PM
Bschwarzli's Avatar
I made my own. You will see pics of the spacers in the Crew Cab build thread.
post #10 of 10 (permalink) Old 03-19-2019, 05:41 PM
Kmehr's Avatar
I think I would just cut the tunnel if it were me. I think it would cut down on the total number of things you have to change, and you could make a nice removable panel to make servicing things easier in the future.
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is offline
Similar Threads
Another successful 48RE to G56 6 speed swap MTMike 3rd Gen. Powertrain 72 05-08-2018 04:19 PM
NV5600 Swap for 47re CumminsTDI_Guy21 98.5-02 Powertrain 4 09-19-2016 11:06 PM
1998 12 valve NV5600 swap questions, help etc rtcharged 94-98 Powertrain 19 03-04-2016 08:38 PM
thoughts on nv5600 swap.. AAZ Racing 98.5-02 Powertrain 0 05-21-2013 01:05 AM
Nv5600 swap out auto... Questions...spedo ...splines 4doogie 94-98 Powertrain 12 02-09-2013 03:56 PM
