1989 RWAL Code Scanning - Page 2 - Dodge Cummins Diesel Forum
 1Likes
post #13 of 22 (permalink) Old 03-19-2019, 01:51 PM
Bschwarzli's Avatar
I will also add there is 9 codes the box will spit out. 9/10 times, I have found it to be greenrot in the sensor cable that goes between frame connection and axle.
Robert
1980 Dodge W350 Crew Cab Dually, 97 12V, HX35/HT3B, 24 speed, Air ride, SRT8 interior, D80, Np205, D60F
1990 W250 24 spd, not close to stock, Super HX40, ASA intake - 2008 2500 Mega 6.7 68RFE
Bschwarzli is offline
post #14 of 22 (permalink) Old 03-19-2019, 01:55 PM Thread Starter
Oh awesome thank you also, I turned the key to the on position and grounded out the single pin on the diagnostic connector and I could not get any codes to flash, it just stayed solid lit. I grounded to the glovebox light, battery terminal, and engine block, and nothing.
1989sligo is offline
post #15 of 22 (permalink) Old 04-03-2019, 10:55 AM
9297oldram's Avatar
What ever happened with this in case someone else may want a RWAL fixed?
9297oldram is offline
post #16 of 22 (permalink) Old 04-03-2019, 11:30 AM Thread Starter
No matter what I do I cannot get the light to flash. I found the diagnostic connector and it has one pin inside. I grounded that to many different places with the key in the "run/on" position and no flashing. Every grounding point I tried was a good ground and I waited up to 5 minutes with each so I am somewhat lost on it.
post #17 of 22 (permalink) Old 04-03-2019, 11:34 AM
9297oldram's Avatar
That's why everyone just unplugs the black box and doesn't worry about it.
post #18 of 22 (permalink) Old 04-03-2019, 11:36 AM Thread Starter
Yeah, I know. I am going to throw a valve unit at it. Not too bad at $100 on RockAuto and redo the brakes and brake lines and bleed it really good. If the light goes off, great, if not I will concede defeat, unplug the box, and move on.
post #19 of 22 (permalink) Old 04-03-2019, 11:40 AM
9297oldram's Avatar
When the valve goes bad that's what usually sets off the light so replacing the valve will probably shut the light off.
post #20 of 22 (permalink) Old 04-03-2019, 11:44 AM Thread Starter
Okay great. The truck sat for 10 years before I bought it so I don't doubt that is the issue
post #21 of 22 (permalink) Old 04-03-2019, 11:49 AM
9297oldram's Avatar
The valve is probably froze up then if it was sitting for that long.
post #22 of 22 (permalink) Old 04-03-2019, 11:52 AM Thread Starter
yeah that's what I am thinking/hoping. I need all new brake lines anyways so I will just do it then. I will be sure to post failure or success here.
Similar Threads
Po606 death code. Pic replaced code left and popped up again truck runs well Sonicdieselmonkey 98.5-02 Powertrain 1 08-03-2015 07:33 PM
po336 code. replaced crank sensor, code still there Clint3 98.5-02 Powertrain 9 04-17-2015 04:28 PM
P0341 code (06 5.9) rollincoal06 3rd Gen. Powertrain 3 12-21-2013 09:30 PM
Limp mode..but no code? monster50iii 3rd Gen. Performance Parts Discussion 2 10-12-2012 08:32 PM
HELP!! Getting code after putting DPF back on Rockrunner Colorado 15 07-02-2011 01:11 PM
