91 to 98 p-pump swap help - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 03-05-2019, 10:25 PM Thread Starter
SmithN8or's Avatar
I’m looking into buying a 91 W250 I found. The owner swapped in a p-pump motor from a 98, built the motor some and added compound turbos. No dyno, but he’s estimated 500 RWHP. Anyway, the truck needs some TLC and would be a fun project truck. He said it runs strong and he’d drive it cross country at the drop of a hat. The help I’m looking for is that the cruise control doesn’t work. He never figured out how to get it to work from going from the VE motor to the p-pump. Any suggestions?
SmithN8or is offline
post #2 of 4 (permalink) Old 03-27-2019, 03:02 PM
Baxter's Avatar
Is the cruise cable connected to the throttle linkage at all? As far as I can tell that's the only part that would be different or need fabbed. Could be the cruise didn't work before the swap?
Google Mechanic Extraordinaire
92 W250, Automagic, 4" lift, 37's, BHAF, 4" TBE, 175hp P-pump, 16.5*, DDP fuel plate, DAP 5X.014s, GSK(?), 60lb. ex. springs, HE351CW, P/S I/C.
Baxter is offline
post #3 of 4 (permalink) Old 03-27-2019, 05:33 PM
Moderator
9297oldram's Avatar
The cruise control is usually one of the first things to go on one of these old trucks. The clock springs or the buttons on the steering wheels.
9297oldram is offline
post #4 of 4 (permalink) Old 03-27-2019, 06:53 PM Thread Starter
SmithN8or's Avatar
Thanks guys. I’ll look into that.
Similar Threads
Water pump recall Aaron37 2013+ General Discussion 2273 03-14-2019 11:02 AM
Straight Foward Answers to Common Questions! DavidRasch17 98.5-02 Performance Parts Discussion 100 11-17-2017 11:36 AM
Ram will not accept throttle? Pig Iron 98.5-02 Powertrain 5 10-29-2011 11:50 AM
New installed quadzilla now DTC codes!!! fastracing 98.5-02 Powertrain 8 10-11-2011 12:29 PM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
