Lost overdrive again - Dodge Cummins Diesel Forum
post #1 of 27 (permalink) Old 03-03-2019, 05:03 PM Thread Starter
Guys I'm beating my brains in over here. I went pot mod when the TPS looked like it was garbage. Bypassed both the temp sensor on the block and the transmission. I've put hundreds of miles on it with zero issues until today. Went to drive home from work and I had no speedo or overdrive whatsoever.
What am I missing? VSS?
gongchuan is offline
post #2 of 27 (permalink) Old 03-03-2019, 05:17 PM Thread Starter
And I lost in, not list it. Fat fingers + no patients + spell check = bad news.
Thanks in advance.
post #3 of 27 (permalink) Old 03-03-2019, 06:11 PM
Vss is likely, could be wiring too.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #4 of 27 (permalink) Old 03-03-2019, 06:14 PM Thread Starter
Problem is, possibly also, VSS is connected via a short speedometer cable. I have a US gear underdrive.
What kind of wiring issues? I don't think I'm ready for that
post #5 of 27 (permalink) Old 03-05-2019, 03:50 AM Thread Starter
Put a new VSS in yesterday. High fived myself after the test run. Got overdrive back. Thought I had it licked till I drove it in to work this morning, no overdrive again. What else is there guys?
What else controls both the speedo, and the overdrive?
I have a pot mod, I bypassed both temp sensors in the block and trans, replaced the VSS yesterday. What else am I missing? What could be intermittently working/not working that controls both the speedo and overdrive?
post #6 of 27 (permalink) Old 03-05-2019, 07:18 AM
Moderator
9297oldram's Avatar
A bad wire, possibly shorting out somewhere?
9297oldram is offline
post #7 of 27 (permalink) Old 03-05-2019, 08:15 AM Thread Starter
A strong possibility. Where does the VSS wire go initially?
post #8 of 27 (permalink) Old 03-05-2019, 08:16 AM Thread Starter
What would control both the speedo and the overdrive?
post #9 of 27 (permalink) Old 03-05-2019, 11:10 AM
myother4x4isaCJ7's Avatar
The vss, there is a couple other things but the vss is the main culprit.
myother4x4isaCJ7 is offline
post #10 of 27 (permalink) Old 03-05-2019, 11:13 AM Thread Starter
I replaced that bad boy yesterday. Is there a way to check if it's working out not? Chuck a drill on it and test with a volt meter or something?
post #11 of 27 (permalink) Old 03-05-2019, 12:18 PM
Moderator
9297oldram's Avatar
You could do the drill thing, the ECM also gives it something like 5 volts I believe. Does your VSS screw onto a ratio adapter if so they are prone to breaking.
post #12 of 27 (permalink) Old 03-05-2019, 12:29 PM
chrislib's Avatar
crank sensor, do the air conditioning work and cruise control work?
93 W250 CC,518/Goerend converter/TransGo,7x010s, pump tweaked,piston lift pump,M&H #2 pin, 3200 spring,Hybrid 35/40, 4in DP/5in from the t-case back, 2.5in. Alcans in front
chrislib is offline
Similar Threads
lost speedo, rpm, and overdrive...all at same time! joelykool 94-98 Non-Powertrain 17 07-02-2016 01:42 PM
Overdrive 4th quit working won't engage with manual switch Mrosen12 94-98 Powertrain 1 11-04-2015 12:12 AM
overdrive testing 47re as140672 94-98 Powertrain 5 04-12-2015 12:36 PM
47RE transmission troubleshooting chart. country_hick 94-98 Powertrain 0 02-25-2013 12:30 PM
Lost overdrive in my 94 dieselhead29 94-98 Powertrain 5 11-25-2012 11:29 PM
