My W250 Project - Page 2 - Dodge Cummins Diesel Forum
 10Likes
post #13 of 35 (permalink) Old 02-18-2019, 08:39 PM
Truckjerk's Avatar
Nice work and thanks for sharing, looking forward to seeing it come back to life!
2014 Ram 2500, 6.7, 6 Speed Manual
1993 Ram D250, 2WD Cummins 5-speed.
Truckjerk is offline
The Following User Says Thank You to Truckjerk For This Useful Post:
mikemmw (03-12-2019)
post #14 of 35 (permalink) Old 02-18-2019, 10:11 PM
hwork50's Avatar
This is fantastic! You are doing such a great job as I am looking forward to seeing your progress. Keep up the good work.
1998 SLT - 12 valve auto 4x4 / 4" MBRP /3 k springs / hx35/40 turbo / Thuren / Deaver suspension
hwork50 is offline
The Following User Says Thank You to hwork50 For This Useful Post:
post #15 of 35 (permalink) Old 03-11-2019, 07:30 AM Thread Starter
mikemmw's Avatar
I had another blasting session and got all the pieces I removed from the frame cleaned up then primed and painted them black.
I gave my new springs a quick coat of gloss black as they'd got a bit scratched and scuffed on their long journey.
I decided to go with Skyjacker 4" lift springs
Next I got everything bolted back onto the frame, I did away with all the old school imperial bolts and used all metric.
When it was all bolted together I went over everything with a Waxoil/underseal.
What I used is called Bodysafe, it's a thick tar like stuff that I just add a touch of thinners to then apply it liberally with a shutz gun
This stuff dries over night but it's tacky for up to a couple of weeks after depending on temperature. So I'm waiting until its a bit drier before I can do much more with the frame. I'd like to get the leafs on this week so they are out of the way and I can put the axle stands under them instead of onto the tacky frame.
thrashingcows likes this.
2015 VW Amarok
2004 Ram 1500, 5.7, RHD converted
1992 W250, red/white, automatic, currently undergoing restoration
mikemmw is offline
post #16 of 35 (permalink) Old 03-11-2019, 09:27 PM
thrashingcows's Avatar
Sure go with the Metric stuff....not going to restored properly then....
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 350K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
The Following User Says Thank You to thrashingcows For This Useful Post:
post #17 of 35 (permalink) Old 03-11-2019, 09:27 PM
Looking great....be better then new when your done!
post #18 of 35 (permalink) Old 03-12-2019, 05:22 AM Thread Starter
mikemmw's Avatar
Haha before starting this project I had to buy a load of sockets and spanners (wrenches), instead of having whole numbers written on them denoting the nut size they fit they all have fractions written on them. I'm still yet to figure out their relevance.
Any job takes me longer as I can't just look at a bolt and know off hand what size it is like I do with metric so have to go to my tool box and grab a handful and bring them all to where i'm working.
2015 VW Amarok
mikemmw is offline
post #19 of 35 (permalink) Old 03-12-2019, 05:23 AM Thread Starter
mikemmw's Avatar
Thanks, the frame might be. Can't see the other parts been brought up to the same standard though
2015 VW Amarok
mikemmw is offline
post #20 of 35 (permalink) Old 03-12-2019, 04:43 PM
But at least when working on the cummins engine it's all metric bolts. But I do understand, I look at a nut or bolt and say...that's a 3/8, 1/2 or 9/16, but then come back with appropriate wrenches and realize it's a 10mm, 13mm or 14/15mm.
post #21 of 35 (permalink) Old 03-12-2019, 06:43 PM Thread Starter
mikemmw's Avatar
I had noticed everything engine related was good ol metric. Even on the brand new trucks is everything still imperial?
2015 VW Amarok
mikemmw is offline
post #22 of 35 (permalink) Old 03-12-2019, 08:56 PM
Not sure if all the new vehicles are standard or metric. I want to say more metric then standard....since most of the bolts I have had to remove while working on my wife's 2011 Dodge Caliber were metric.
post #23 of 35 (permalink) Old 04-02-2019, 06:49 AM Thread Starter
mikemmw's Avatar
Not had much progress that's worth posting lately.
I got the front springs fitted which are part of a skyjacker 4" lift kit.
I'd forgot to order new frame bushes so had to make my own.
These are solid bushes made from acetal but I can't see me having any issues with them cracking. Although I've not made solid bushes for anything as heavy as this truck before I have made quite a lot for rally and track car suspension components in the past that take a lot of force and not had a failure I've been told about yet.
If they do crack that's a problem for future me and I'll deal with it then.
I turned them up in my good old Harrison lathe.
I didn't have to make the steel sleeves as I had ordered a spare skyjacker spring bush kit, the bushes didn't fit the frame but the sleeves were correct for the shackles so just made mine to fit these sleeves.
The front springs from skyjacker come with no bushes, I already new this from forum reading so had ordered a skyjacker bush kit for the rear of the spring and had ordered a greasable bolt and bush kit for the front of the spring from jungle on the ramcharger forum as skyjacker don't offer a bush to fit the front of the spring that I could find.
These greasable ones are a better option even if they did.
One thing I didn't account for was that the front spring mount wasn't wide enough with the new bushes fitted as 2 piece bushes are longer than 1 piece because you need a shoulder on each side. Not a big issue you just need to persuade the opening up a bit, I tried for ages to save my shiny frame by trying to portapak it open with no success.
In the end it took 2 minutes with a lump hammer to open them up slightly then when you tighten the bolt up it closes them up again.
Currently I've got a few places on the frame to go round and touch up and I'm sure I'll have a few more before I'm finished.
2015 VW Amarok
mikemmw is offline
post #24 of 35 (permalink) Old 04-02-2019, 07:04 AM Thread Starter
mikemmw's Avatar
Literally 5 minutes after posting the above I got a delivery of truck parts. One thing missed my container departure so had to come on another ship.
It was from skyjacker and I believed it to just be U bolts, well in the box with the U bolts were 2 bags of bushes....typical
2015 VW Amarok
mikemmw is offline
Similar Threads
93 Cummins, new DIY Project. Old Farm truck. DrSkyfall 89-93 Non-Powertrain 6 01-07-2016 08:15 PM
Geno's Garage 2015 Community Service Project Genos Garage Sponsors Marketplace 0 10-20-2015 09:23 AM
Project 93 W250 Raven23 89-93 Non-Powertrain 7 10-15-2015 02:41 PM
Detailed specs for a '92 W250 + Service Body/Camper project 1stGenGene 89-93 Non-Powertrain 29 04-05-2012 09:28 PM
Project '93 W250 ECLB w/ Getrag mbdpp 89-93 Performance Parts Discussion 29 01-03-2011 08:04 AM
