4x4 swap - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By 90rebild
post #1 of 11 (permalink) Old 01-11-2019, 06:44 AM Thread Starter
4x4 swap
looking for more information on changing a 4x2 to 4x4 how hard it is and where to really begin at thank you
Nicholasparis5 is offline
post #2 of 11 (permalink) Old 01-11-2019, 07:33 AM
Ratdog1's Avatar
Welcome to the forum. .
From all the threads asking this question.
The end result is.
Way to much work involved get a 4x4 doner .
Im sure the smart guys will fill you in ...
Sent from my SAMSUNG-SM-T217A using Tapatalk
2016 4x4 3500 Laramie CCLB LOST MY EXHAUST SO I HAVE AN 18 INCH RESONATOR AND EGRDELETE.. ALSO HAVE EFILIVE BY PPEI
3.42 rear ,68 trans TUNED BY PPEI
Ratdog1 is offline
post #3 of 11 (permalink) Old 01-11-2019, 09:11 PM
19cummins92's Avatar
Second that, you need a doner. If nothing else just to pull measurements from. You can do it with hand tools. I converted a 2nd dually crew cab to 4wd one time. I think I had to drill (27) 1/2" holes to bolt everything in. The only thing I needed a torch for was to cut (2) 2" diameter holes in the frame for the rear leaf spring hangers. You will have to take everything off the frame rails back to about the Trans mount.
'92 W350 cc/sb project, '89 W250, '91 W250, '90 D350,'92 D250... Its all junk!
19cummins92 is offline
post #4 of 11 (permalink) Old 01-12-2019, 04:06 PM
2x to 4x
i'm in the middle of doing that now. it is a lot of work, for sure. my old '89w250 was rusted to pieces so i bought a 2wd d250 in arizona and completely tore it down, cut out the 2wd stuff, sandblasted everything, por15'd all the parts and bolted stuff back together using flange head, grade 8 nuts and bolts taking measurements off the old frame to know where the x-members go. rebuilt the diffs, transmission, engine (it only had 400k+ miles) new everything to do with the brakes, new hubs, leaf springs and on and on. i'm ready to put the drive train into the frame now and then start on the body, thinking it has to get taken down to bare metal for new paint. going to put some sound deadener in the cab too. before you needed to wear earmuffs to safeguard your hearing and some kind of eyeball restraints to keep them from rattling outta your skull.
so what i'm going to end up with is an OLD truck that won't be worth half the money I've spent on it... but it'll be a great old truck
simplysmn likes this.
90rebild is offline
post #5 of 11 (permalink) Old 01-13-2019, 02:25 AM
simplysmn
simplysmn's Avatar
iTrader Score: 11 reviews
4x4 swap is Simple .Easy No worth doing heck yeah . Best thing is get a 4x4 donor and cut the frame right at front cab mount and then trim it down to flat plate . Bolt it up to truck frame Mark holes and Drill Away . Very Simple to do .you have Question's just message me . I have it down to a science .
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto sxe62/70 turbo 6x13 injector's full 4 in Diamond Eye Exhaust ,366 spring and THD fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #6 of 11 (permalink) Old 01-13-2019, 04:45 PM
thrashingcows's Avatar
You can check out my crewcab build thread, tons of pics and info....I did the 2wd to 4wd conversion about 5 years ago now. Yes it's lots of work, but not that bad.
https://www.dieseltruckresource.com/...update-305923/
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 350K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #7 of 11 (permalink) Old 03-22-2019, 08:21 AM
Is there any chance someone on here would have those frame sections for templates?
Radtke is offline
post #8 of 11 (permalink) Old 03-22-2019, 03:41 PM
simplysmn
simplysmn's Avatar
If you have a 4x4 truck you can make your own templates send me a Message I can show you how .
post #9 of 11 (permalink) Old 03-23-2019, 01:45 PM
Your build is amazing. Just sat here forever going through. Any photos of its fully completed?
-92d350
articmonke is offline
The Following User Says Thank You to articmonke For This Useful Post:
thrashingcows (03-23-2019)
post #10 of 11 (permalink) Old 03-23-2019, 02:17 PM
Easier to do a cab an engine swap onto a rolling chassis donor. Even easier and cheaper , sell it and buy a 4x4.
bigfish95971 is offline
post #11 of 11 (permalink) Old 03-23-2019, 02:34 PM
Moderator
9297oldram's Avatar
Good clean 1st Gens aren't as easy to find as the 2nd and 3rd Gens. 4x4's are even harder to find in good condition.
9297oldram is offline
