Truck shutoff - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-18-2018, 08:39 AM Thread Starter
Exclamation Truck shutoff
My 1992 w250 cummins shuts off when i press the brake in drive or reverse.I go and push the brake and it shakes then shuts off.Everything i looked up says fss but i wanted you guys input.How do i fix this??!!
JohnnyMark is offline
post #2 of 6 (permalink) Old 06-18-2018, 09:05 AM
Moderator
9297oldram's Avatar
Check the terminals at the FSS to make sure they are tight, if they are tight then you probably have a wire going to ground for the FSS. If I remember it's a blue wire that's the key on power for the FSS.
9297oldram is offline
post #3 of 6 (permalink) Old 06-18-2018, 09:13 AM
Hard braking or just pushing the peddle? Will it do it while stationary?
If checking the FSS wiring does not show anything, disconnect the brake light switch and see if it still cuts out.
Cheers Steve
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, Aftermarket AFC spring, re-set injectors. tuning in progress
Blackduck59 is offline
post #4 of 6 (permalink) Old 06-18-2018, 05:51 PM Thread Starter
hard braking,like coming to a complete stop.especially while on a hill.
post #5 of 6 (permalink) Old 06-18-2018, 05:54 PM
Moderator
9297oldram's Avatar
I'd almost bet on loose connection at the FSS.
post #6 of 6 (permalink) Old 06-18-2018, 07:36 PM
Certainly sounds like loose wiring
