Tie rod ends - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 06-03-2018, 09:37 PM Thread Starter
Tie rod ends
I have a 91 non-ic w250 single cab long bed 4x4, and Im replacing most of the front end parts and now Im onto tie rod ends. I looked on rock auto and found the Moog tie rods for 3500 lbs drive axle can someone enlighten me on what this means? They also have a 4500 lbs drive axle. Im lost.
Quadtrac440 is offline
post #2 of 11 (permalink) Old 06-04-2018, 11:30 AM
9297oldram's Avatar
More than likely the 3500 is the Dana 44 and the other is the Diesel Dana 60 front. Whenever buying parts for the Diesel Dodge you need to be sure it says Diesel.
9297oldram is offline
post #3 of 11 (permalink) Old 06-04-2018, 11:52 AM
myother4x4isaCJ7's Avatar
Went through this recently, most parts house computers will still list Dana 44 parts for the diesel. I ended up bringing my tie rods in and matching them up. I can get list the part numbers for the OP if he is interested
myother4x4isaCJ7 is offline
post #4 of 11 (permalink) Old 06-04-2018, 11:57 AM
9297oldram's Avatar
I won't buy anything on line unless I know the part number is right, to much hassle returning the parts and waiting for the right ones.
post #5 of 11 (permalink) Old 06-04-2018, 12:03 PM Thread Starter
That would be great! I want to buy them once and not have to go through the hassle again. Thanks guys, I appreciate it
The Following User Says Thank You to Quadtrac440 For This Useful Post:
9297oldram (06-04-2018)
post #6 of 11 (permalink) Old 06-04-2018, 12:51 PM
I used ES2010R and ES2010L should be the same for you. 4500lb weight for all diesel trucks I believe
post #7 of 11 (permalink) Old 06-04-2018, 01:15 PM
Blue Goose's Avatar
I got my Moog tie rod ends off of Rock Auto, made in USA. They also had ones listed for $1.78....now that;s a scary thought.
'81 D150
Blue Goose is offline
post #8 of 11 (permalink) Old 06-04-2018, 01:36 PM Thread Starter
Thanks!
post #9 of 11 (permalink) Old 06-04-2018, 10:36 PM
Death Row Dave's Avatar
Dana 61
I had a 90 Sno Commander front axle weight listed on door tag was 4000 lb . It was a Dana 61 . 99.99% of the time CTD powered trucks have 4500 lb front axle Dana 60
Death Row Dave is offline
post #10 of 11 (permalink) Old 06-05-2018, 09:05 AM
peckens's Avatar
Once I get my part numbers right I usually get them on amazon or summit. Way cheaper and usually free 2 day shipping. Of course I usually order parts way in advance. So I have them when I actually have time to do it.
1993 W250 ext cab a518 (Revmax t/c) 4.10, 366 spring; timing bump; Red Head steering gear w/ Dodge Connection brace, bhaf, DAP 5x12 sac injectors
peckens is offline
post #11 of 11 (permalink) Old 06-05-2018, 09:21 AM
9297oldram's Avatar
Your right I buy alot of parts on Amazon once i've researched to get the correct PN.
