How to remove rear brake drum on '92 Dodge D250 3/4 ton - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 06-01-2018, 11:00 PM Thread Starter
Unhappy How to remove rear brake drum on '92 Dodge D250 3/4 ton
I was trying to inspect or change my rear brake self-adjuster. I have adjusted the adjuster on the back side of the wheel but after 3 days it 'resets' itself to where the brakes on this wheel are extremely sensitive and skids when applied.
I removed the wheel and saw the huge brake drum and another piece with bolts which I guess is the axle. I pulled on the drum and it wouldn't budge. Do I have to remove the axle so I can remove the drum? I've heard that on later 3/4 ton trucks, that you can do a trick without removing the axle and the drum will come off. Can it be done on my '92 truck?
This is driving me crazy with the one wheel is so touchy and skids with the slightest pressure. I've adjusted the adjuster 5 times from the rear access hole but returns in a few days as very sensitive. I am afraid on a wet day, I will skid into someone because the wheel locks up. While adjusting on the rear access hole, I've noticed that the teeth of the adjuster are very worn.
Any help is appreciated.
Thanks
Will
dancingcajun is offline
post #2 of 10 (permalink) Old 06-01-2018, 11:40 PM
myother4x4isaCJ7's Avatar
Thanks
Will
Need to buy a 2 9/16 axle nut socket it has to have rounded edges I believe. Then you remove the axle shaft and use that socket to remove the large nut holding the drum and hub onto the axle housing.
myother4x4isaCJ7 is offline
post #3 of 10 (permalink) Old 06-01-2018, 11:46 PM Thread Starter
Thanks for the advice
Have a good night and weekend.
post #4 of 10 (permalink) Old 06-02-2018, 07:19 AM
Make sure you hold back the adjusters and back them off all of the way or you might never get the drum off if the shoes touch the drum.
Be careful you do not damaged the seals when lift the drum back on to the axle tube,
You will see once you have it apart.
Jim
Jim L is offline
post #5 of 10 (permalink) Old 06-02-2018, 08:13 AM
NIsaacs's Avatar
The reason the brake locks up, is there is probably a leak in the wheel seal or wheel brake cylinder and has gotten on the brake shoe. If there is, you will need to replace the shoes because you can't clean them enough to not lock up, and of course fix the leak.
Nick
1974 Ford F-350 Dually, Cummins 359, 5spd, 3spd Aux.... '01 Dodge 2500, 4x4, 6spd.... '91 Dodge D-250, 5spd
NIsaacs is offline
The Following User Says Thank You to NIsaacs For This Useful Post:
thrashingcows (06-02-2018)
post #6 of 10 (permalink) Old 06-02-2018, 01:56 PM
Nick
I second this, I actually suggested that to him in another thread. Pretty common issue with drum brakes.
The Following User Says Thank You to myother4x4isaCJ7 For This Useful Post:
post #7 of 10 (permalink) Old 06-02-2018, 02:17 PM
KATOOM's Avatar
This thread may help. https://www.cumminsforum.com/forum/89...1-3-4-ton.html
KATOOM is offline
post #8 of 10 (permalink) Old 06-03-2018, 10:34 PM Thread Starter
thanks for the suggestion
post #9 of 10 (permalink) Old 06-03-2018, 10:35 PM Thread Starter
thanks for your help
post #10 of 10 (permalink) Old 06-03-2018, 10:47 PM
KATOOM's Avatar
You're welcome.
KATOOM is offline
