1992 w250 Cummins - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 05-29-2018, 11:45 PM Thread Starter
1992 w250 Cummins
I have a 1992 Cummins that has a rusty cab so I bought a new, rust free cab from Arizona. The problem is that the cab is off of a gasser. I am wondering how difficult the wiring would be, or if it would even be worth it to try and if I should just get a cab off of a Cummins??
Will Beevers is offline
post #2 of 5 (permalink) Old 05-30-2018, 02:37 AM
myother4x4isaCJ7's Avatar
If the harness from your Cummins truck is in good shape everything should work just fine if you swap that harness into the donor cab. But in all reality the Cummins only needs 1 wire to run so if you have to use the gasser harness Iím positive it can be made to work.
myother4x4isaCJ7 is online now
post #3 of 5 (permalink) Old 05-30-2018, 10:42 AM
9297oldram's Avatar
You'll need the Diesel Radiator support from the 92 so that you can use the intercooler.
9297oldram is offline
post #4 of 5 (permalink) Old 05-30-2018, 04:19 PM
thrashingcows's Avatar
What year of a truck is new donor cab? There were a few small differences in years...wiring bulk head connector size and shape, couple holes needed or added etc, but a pretty straight forward swap with no need to find another cab. You'll just have to tear both cabs right down and swap parts.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #5 of 5 (permalink) Old 05-30-2018, 04:51 PM
Tinkerman92's Avatar
Please continue to post on your "swap". I to have a 1992 with a rotten cab and will be following with interest. Could be I won't have to drive a convertible after all!
1992 W250, Banks Power Pack, Warn 8000 winch, the rest is stock 280,000 miles
Tinkerman92 is offline
