isspro r8503+wire kit issue on 92 - Page 2 - Dodge Cummins Diesel Forum
 1Likes
post #13 of 24 (permalink) Old 05-09-2018, 09:40 PM Thread Starter
nick05's Avatar
ok i’ll double check but i didn’t see an external reg on it.
so i don’t get why the tach isn’t working then. i’ve spoken with isspro already and went thru what they told me to check.
all is hooked up correct but i don’t know what the issue is.
judt confused
i’ll go thru it all again to triple check
1992 w250 cc, 5spd "in progress"
98 12v cclb 5spd 4wd
nick05 is offline
post #14 of 24 (permalink) Old 05-09-2018, 10:04 PM
9297oldram's Avatar
judt confused
I'll explain how the CPS works, when the ECM gets a signal from the CPS that the engine is running it pulls in the ASD relay and the charging, A/C and a few other functions the ASD controls works. In order for the CPS to work it has to have a air gap of .050, so if your charging system works then the CPS works.
You might need to get a FSM so that you can see if there is a problem with the wires that go to the wiring in the cab.
9297oldram is offline
post #15 of 24 (permalink) Old 05-09-2018, 10:10 PM Thread Starter
nick05's Avatar
ok great info. appreciate it. then let me ask you this, possibly junk tach, any way to test it?
nick05 is offline
post #16 of 24 (permalink) Old 05-10-2018, 12:35 AM
myother4x4isaCJ7's Avatar
Ill bet isspro will test it for ya. Was it brand new or used?
myother4x4isaCJ7 is online now
post #17 of 24 (permalink) Old 05-10-2018, 09:49 AM Thread Starter
nick05's Avatar
dang it! why did i forget to ask isspro yest? ugh. yes gauge is new.
i’ll get this figured out soon and report back who’s error was is.
gauge, truck , or operator
thanks again for the assistance fellas
nick05 is offline
post #18 of 24 (permalink) Old 05-10-2018, 10:07 AM
9297oldram's Avatar
Have you checked the wires in the cab for volts, and are you using the right connector?
post #19 of 24 (permalink) Old 05-10-2018, 10:16 AM Thread Starter
nick05's Avatar
lol yes or i hope so. 2 black 1 orange 1 grey lightblue. (connector)
verified thru connector—have good ground, have 13.8v key on and .1v on the signal wire.
i don’t remember if the signal wire was flashing between.1v and 5v or whatever it’s supposed too for signal output.
maybe i need to tap into black wire off gauge and put it to ground closer as directions state?
i will be checking everything over again tonight when i get home. i’ll write it down on paper for my checklist
nick05 is offline
post #20 of 24 (permalink) Old 05-10-2018, 10:55 AM
9297oldram's Avatar
Just for testing run a good ground from the battery neg and tie the grounds on it.
post #21 of 24 (permalink) Old 05-10-2018, 08:38 PM Thread Starter
nick05's Avatar
ok I ran out of time but did a quick check on the wiring.
red has 14v key on
green has power when light switch pulled
ground is good and ran a separate wire to battery neg. made no diff.
grey/blue tracer has .15v reading with truck running.
also ran a separate wire off cps signal wire underhood to isspro harness bypassing factory wire. yellow and white. no diff.
still no reading.
now the only thing I didn't do all at once, is run the separate signal wire bypassing the factory truck wire, along with a neg wire direct from battery. didn't have enough gator clips or a helper.
now I got a little ahead of myself when I first started testing and forgot to plug in the cps. truck started but volt gauge read low. I realized wtf, then plugged back in. volt gauge reads normal location.
so what does the signal wire voltage put out? i tried ac and dc voltage. guy at isspro told me to have my meter on ac.
idk it's almost Friday. time for tails
nick05 is offline
post #22 of 24 (permalink) Old 05-13-2018, 08:48 PM Thread Starter
nick05's Avatar
well guys figured it out.
thru on a new cps, still didn't work thru factory plug, BUT,
ran a separate wire from cps sig wire straight to gauge, boom we have rpm.
so somewhere between the ecm and factory connector it has a break. was not getting the same reading direct from cps.
kinda odd when I ohm'd the wire connections to and from ecm, checking out ok before.
thanks again for the pointers and help, on to the next headache.
thrashingcows likes this.
nick05 is offline
post #23 of 24 (permalink) Old 05-14-2018, 04:02 PM
thrashingcows's Avatar
Glad you got it figured out.....and way to persist until you found the problem!
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is online now
post #24 of 24 (permalink) Old 05-26-2018, 12:05 AM
So i bought the 4k flat face tach
Thought ide save money didnt buy the harness, turns out i dont have a signal at all from wire in fact harness, so i hard wired to back of alt off one of those screws, now turn key goes str8 to 1000k but sticks there doesnt move, even turn off stays there,
I bought a 0.0047 capacitor but not from radio shack, that is only way my tach will move, if i just go str8 to wire no signal, but i get the jump to 1000k of ignition with capacitor in line
Im super frusterated and would like to know what capacitor to use
The one i bought was from florida and took 2 weeks to get cost 25c but is 1000v and the radio shack one is 500v
Please someone understand at all what im asking, i know tack works just have to find right filter lol
Thank you for your patience for my long post but first gens are worth it
spencejordan is offline
