1st gen restoration/ replacement part websites that i found. - Page 5 - Dodge Cummins Diesel Forum
 2Likes
post #49 of 51 (permalink) Old 10-15-2017, 07:22 PM
thrashingcows's Avatar
aftermarket steering box adapter
A new member over on the DTR just posted this up.....
Originally Posted by Jon Sharpe
I found an aftermarket steering box mounting bracket Offroad Truck Parts & Car Restoration - Autofab will lead you to it is beefy and well engineered the best $225 it may need some minor work the mounting holes are drilled at 1/2" they will need to be 9/16 for the original bolts front and rear the bottom bolt that you have to press/drive in will need to be a 19/32" hole the early trucks actually have 1/2" bolts (make sure you check prior to drilling) it is a close tolerance piece and will need to be pressed tightly to the steeting box before starting the bolts to insure proper fit. it is an incredibly well designed quality part !
That looks like a great product! Thank you for posting that up....sure there are more then a few people who need this.
Here is a direct link to it....
1972-1993 Dodge 4x4 Truck / Ramcharger Steering Box Mounting Bracket
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #50 of 51 (permalink) Old 03-24-2018, 02:29 PM
9297oldram's Avatar
I just found another website not listed parts
9297oldram is offline
post #51 of 51 (permalink) Old 11-18-2018, 07:51 PM
ndillon's Avatar
So i might repeat a few websites here and there but maybe someone can gain some benefit from this. I've gotten specific parts from each website while rebuilding the whole truck. im just taking everything from my bookmarks.
https://www.xtremediesel.com/
http://www.industrialdiesel.com/
https://www.jcwhitney.com/
https://www.jimsautoparts.com/nos_truck_parts.htm
https://www.rockauto.com/en/catalog/dodge,1991
https://www.summitracing.com/
https://keatingmachine.com/
https://skyjacker.com/
https://www.genuinedieselpart.com/
Dodge Truck Parts - NOS and Used Dodge Truck Parts - Mopar Truck Parts
https://www.dieselpartsdirect.com/
REBUILT MANUAL TRANSMISSION
DODGE - PICKUP (full size) - 1981-1993 - Page 1 - Autobody Specialties
https://www.carparts.com/
https://www.autoandtrucksprings.com/dodge-leaf-springs
Online Automotive Truck and Car Parts Accessories at PartsTrain.com
https://www.accmats.com/
https://raybuck.com/panels/dodge/?fwp_year_single=1991
Dodge Ram Trucks & Vans Repair
https://www.discountbodyparts.com/
Car-Part.com--Used Auto Parts Market
D&J Precision Machine ? Diesel Performance Machining & Manufacturing
Hellmann Performance - Aftermarket Truck Parts, Diesel Performance Parts, Diesel Truck Parts
https://www.industrialinjection.com/
https://fleeceperformance.com/
https://redheadsteeringgears.com/
https://steedspeed.com/
https://www.thoroughbreddiesel.com/
https://www.rollinsmokediesel.com/cat-89-93-cummins.cfm
https://www.dieselpowerproducts.com/...89-93-59l.aspx
https://www.stockinteriors.com/
https://garofaloent.net/site/
https://far-from-stock.myshopify.com/
https://www.overkillfab.com/index.cfm
https://archivegarage.com/t/suspension
https://zzdiesel.com/
https://www.autoanything.com/
BlueLakeOffroad
https://www.moparpartsgiant.com/
https://torqueking.com/
Some of these are NOS/OEM/Aftermarket parts websites; some are upgrades and some are custom fab work. Enjoy and hope it helps someone out.
ndillon is offline
