My 1993 club cab 4x4 - Page 3 - Dodge Cummins Diesel Forum
 28Likes
post #25 of 78 (permalink) Old 02-07-2017, 08:28 AM
justinfonder's Avatar
Originally Posted by myother4x4isaCJ7 View Post
Cool that will make putting it on pushbutton easy if I have to. I may end up either narrowing the bed or replacing it but that all depends on how it looks. I've had bad experience with wheel adapters or I would consider keeping it dually.
from the sounds of it, i don't think those wheel spacers wouldve given you much problems, lol.
that single wheel rear axle is gonna be pretty narrow for that bed. i think you'll get it converted to SRW and then think to yourself "man, this thing looked good on duals" haha. maybe it just needs a good set of winter tires on the dually setup?
i love the utility of the flatbed and it's a heck of a lot easier to repair/maintain than a regular box.
mknittle likes this.
'67 D100 on '89 D350 chassis/12v/a518 --- '88 Ramcharger on '93 W250 chassis/12v/47rh --- '93 W250 race truktor --- '03 1500 shorty 12v/a518 --- 12 3500 cclb studded, deleted, tunez, 5
justinfonder is offline
post #26 of 78 (permalink) Old 02-07-2017, 08:32 AM
Moderator
9297oldram's Avatar
All you have to do is run a ground wire from the pushbutton to the terminals that are not 12v. That's the way I did it on my conversion.
9297oldram is offline
post #27 of 78 (permalink) Old 02-07-2017, 10:16 AM
You can even get a timer relay. Did this on a 6.5 Chevy on the farm after wiring some glow coils into the intake. Push button, relay holds shut for 10 seconds.
post #28 of 78 (permalink) Old 02-07-2017, 12:17 PM Thread Starter
myother4x4isaCJ7's Avatar
yea Im not selling the dual setup until I am happy with the look of the truck, that way I can return it to dual if needed. my wrecked truck had tires with less than 1k miles on them and the duals are pretty bald. sadly the new tires are different than the duals or id just use them.
1993 w250 club cab ,flatbed, he351cw, 60# springs, THD Pin, 3200 gov spring,4" diamond eye, THD 5x12 vco and HVLP.
myother4x4isaCJ7 is offline
post #29 of 78 (permalink) Old 02-07-2017, 05:47 PM
I was just thinking about you today when I ran across this CL link https://spokane.craigslist.org/pts/5993551542.html Anywho, glad you got your replacement truck!
You could pick up a newer AAM axle, they are stronger than the 70 and several inches wider as I understand it. Some even came with lockers or torsion limited slip.
'91.5 LE SCLB, HE351CW, 47RH, Swiss Cheese Airbox, THD Lift Pump, THD fuel pin, 366 Spring, 4" exhaust, THD long fuel screw, timing spacer, Pwr Stroke IC, 3" IC piping, Chevy Seats, LED lights.
JeepCJ5 is offline
post #30 of 78 (permalink) Old 02-07-2017, 06:15 PM Thread Starter
of friggin course.... its a twin to my truck other than 5 speed and its 1k cheaper!!! it will be sold in a couple days im sure they go quick around here. my truck does have a limited slip... doesnt help with bald duals though.
post #31 of 78 (permalink) Old 02-07-2017, 06:41 PM
badbowtie's Avatar
I can speak from experience when running duals in snow bald tires really make life hard. The day I bought my d350 it snowed about 2 inches, with the cheater slicks that were on it I couldn't even pull in the driveway.
96 3500 5x018 7mm dvs 62fmw
96 3500 eclb 4x4 5 spd Afc live 5x018 7mm DVDs fmw64.5
91 350 2wd 5 spd thd pin and lift pump
badbowtie is offline
post #32 of 78 (permalink) Old 02-16-2017, 07:07 PM Thread Starter
What trucks should I look for to get the aam? I've decided to keep it single wheel and this summer I will be narrowing my flat bed. Is the second gen Dana 80 any wider than our Dana 70?
post #33 of 78 (permalink) Old 02-16-2017, 07:11 PM
Moderator
9297oldram's Avatar
I think the 2nd Gen Dana 70 is wider than a 1st Gen Dana 70 SRW, I know the Dana 80 is wider.
https://www.cumminsforum.com/forum/89...-question.html
There's your answer ^^^^^^
post #34 of 78 (permalink) Old 02-16-2017, 07:24 PM Thread Starter
Thanks!!! I was searching Google but had not found measurements yet.
post #35 of 78 (permalink) Old 02-16-2017, 07:26 PM
Moderator
9297oldram's Avatar
Use the VB google at the top right of the page, you can do google or VB which is the CF Forum.
post #36 of 78 (permalink) Old 02-16-2017, 07:30 PM Thread Starter
I'm on a iPad knockoff and the search bar here doesn't work unless I use the mobile site and I like the classic WAY MORE!!! So I just use Google, 90 percent of the time the results are all threads from here anyway.
