Fusible link replacement alternative - Page 3 - Dodge Cummins Diesel Forum
 12Likes
post #25 of 35 (permalink) Old 07-11-2017, 08:17 AM
Do you know if on the Freightliner disconnect # A06-72138-013 you listed,
does it need a maintained or momentary closure to operate it?
Looking at the Freightliner schematics and operators manuals, that electrical system is a nightmare especially the way it sheds loads during a circuit failure.
Your truck look clean under the hood, has it been repainted?
Jim L is offline
post #26 of 35 (permalink) Old 07-11-2017, 04:25 PM Thread Starter
Truckjerk's Avatar
It is a maintained switch, Freightliner uses switch part number A06-88420-000 if the battery cutoff option is installed.
Thanks, the truck is being restored; here is the build thread:
https://www.cumminsforum.com/forum/89...t-old-red.html
2014 Ram 2500, 6.7, 6 Speed Manual
1993 Ram D250, 2WD Cummins 5-speed.
Truckjerk is offline
post #27 of 35 (permalink) Old 12-13-2018, 09:29 AM
jerryd's Avatar
I’m kinda late to the party but I have a 90 model and I’m getting ready to do this on I was just wondering if the wire colors would all be the same throughout 89-93
95 ford f-350 4x4 duallie 5spd 12v swapped
THD fuel pin and gsk ps ic 5in exhaust 370s gds 60mm upgrade THD hvlp lp
jerryd is offline
post #28 of 35 (permalink) Old 12-13-2018, 10:42 AM
Moderator
9297oldram's Avatar
The colors should be the same, mainly you need to go by the wire size.
9297oldram is online now
post #29 of 35 (permalink) Old 12-13-2018, 01:03 PM
jerryd's Avatar
Yes I will use the same size wire I just ment where they come out of the main harness the wires be the same colors for the same circuits so I know I’ve gotten them right
jerryd is offline
post #30 of 35 (permalink) Old 12-13-2018, 01:11 PM
jerryd's Avatar
Also I have this mounted on the drivers inner fender between the battery and heater solenoids any idea what it is for
jerryd is offline
post #31 of 35 (permalink) Old 12-22-2018, 11:49 PM Thread Starter
Truckjerk's Avatar
That is the starter relay. The brown wire will go right to your starter solenoid. Red is battery power. Yellows are relay power and ground from the ignition switch.
post #32 of 35 (permalink) Old 12-24-2018, 11:08 AM
jerryd's Avatar
Ahh ok thanks
jerryd is offline
post #33 of 35 (permalink) Old 03-29-2019, 02:05 PM
To all,
The freightliner MIDI/ATC fusbox used in this article is a Blue Sea Systems SafetyHub 100 Fuse Block #7725. I am not going to bother with this one I will be installing a SafetyHub 150 Fuse Block #7748. This allows one more MIDI and two more ATC fuses. I will start a new thread to review the electrical challenges I have had with this 1st gen cummins. I love the truck, but age will bring about changes.
electro_master
electro_master is offline
post #34 of 35 (permalink) Old 03-29-2019, 02:16 PM
Originally Posted by electro_master View Post
To all,
electro_master
The worst problems I have had is fixing what other people have butchered, the people who don't have a clue should not mess with it, I'm sure you probably have some of that to deal with. I will follow your thread for more information you can always learn from others
Sent from my SM-N910P using Tapatalk
7091ram is offline
post #35 of 35 (permalink) Old 03-29-2019, 03:52 PM
justinfonder's Avatar
To all,
electro_master
You’re about 2 years late, lol.
https://www.cumminsforum.com/forum/89-93-non-powertrain/2201802-fuse-link-delete.html
justinfonder is offline
