Tell me about your high lift jack - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 12-01-2015, 05:12 PM Thread Starter
how did you mount your high lift jack on your first gen? did you put it on an aftermarket bumper? which brand jack did you buy? I'd love to know.
Thanks for the info.
kiabe1 is offline
post #2 of 11 (permalink) Old 12-01-2015, 05:36 PM
justinfonder's Avatar
well my truck has this big thing on the back called the bed, thats where i put mine...
'67 D100 on '89 D350 chassis/12v/a518 --- '88 Ramcharger on '93 W250 chassis/12v/47rh --- '93 W250 race truktor --- '03 1500 shorty 12v/a518 --- 12 3500 cclb studded, deleted, tunez, 5
justinfonder is offline
The Following User Says Thank You to justinfonder For This Useful Post:
2011blackcummins (12-02-2015)
post #3 of 11 (permalink) Old 12-01-2015, 05:55 PM
48kenworth's Avatar
That's not nice even though I did get a good chuckle out of it.
To the OP when I need my high lift stowed in my truck I do the same as justinfonder does.
2012 Ford F250 Gasser
SOLD 89 w250 intercooled engine, G56, S300G, piston lift pump, honed stock injectors, 366 spring , 3 piece manifold, 2nd gen CAC, dakota A/C condenser.
48kenworth is offline
The Following User Says Thank You to 48kenworth For This Useful Post:
justinfonder (12-01-2015)
post #4 of 11 (permalink) Old 12-01-2015, 07:43 PM
dan123dbl's Avatar
Mine sits in the shop 99% of the time .. but in the bed like these 2 if I need it. I've seen them bolted to bed rails, tailgates, hoods and front bumpers.
I quite like this guy's setup
hopefully he doesn't mind me posting his picture :P
78-92 W250 Crew Cab in progress -
Zf6, 3.55s, he351vgt, 5x12s, Hydro Boost
dan123dbl is offline
post #5 of 11 (permalink) Old 12-01-2015, 07:58 PM
redtoy's Avatar
Originally Posted by dan123dbl View Post
Interesting setup. I like how the jack is easy to get too however it looks like the jack would get easily fouled by sand, mud, and other stuff kicked up from the tires. The outside of the tailgate or just under the inside of the bed rail are my favorite spots on a fullsize rig. That being said, I consider my highlift's to be more of a last resort type tool.
86 gmc k3500 3+3 tow pig with 92 cummins swap,4" diamond eye,6" lift,36" tires,4.10 gears,he351,6x10 vco,gm nv4500,13" south bend,meth inj, second gen intercooler,3200 gov spring,3" tubes,free pump mods,vintage air.
redtoy is offline
post #6 of 11 (permalink) Old 12-01-2015, 08:48 PM
I have my Hi-Lift brand Hi-Lift jack stored in the extra cab portion of my truck. It keeps it out of all the crap that can cause the springs and pins to stick when you store it outside.
1993 W250 LE Club Cab Long Bed, auto.
wheelerfreak is offline
post #7 of 11 (permalink) Old 12-01-2015, 09:04 PM
simplysmn
simplysmn's Avatar
iTrader Score: 11 reviews
I have had and Used 1 for Year's and can give you some sad stories of Injuries that have Happened from Not using the Jack the right way . The Major thing you have to remember is Keep your Hand's and Arm's away from the handle .It Can be Deadly.and make sure the Vehicle is Blocked at the wheel's .
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto sxe62/70 turbo 6x13 injector's full 4 in Diamond Eye Exhaust ,366 spring and THD fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #8 of 11 (permalink) Old 12-01-2015, 11:58 PM Thread Starter
thx for the safety info. as you may have guessed i'm new to this style of jack so i'll keep that in mind
kiabe1 is offline
post #9 of 11 (permalink) Old 12-02-2015, 12:27 AM
2011blackcummins's Avatar
I don't carry a hi-lift with me but if I did, then I'd throw it in the bed or more securely I'd throw in in my tool box that's in the bed.
'91.5 W250|a518|3.54's|h1c|THD pin|366 spring|M&H timing spacer|HVLP 12psi LP|BHAF|Transpo IN8315|ISSPRO tach, boost, pyro|
2011blackcummins is offline
post #10 of 11 (permalink) Old 12-06-2015, 11:40 AM
Hi Lift makes brackets that mount to the inside of the truck bed. Out of the way and a clean area. Also you will need something to lubricate the mechanisim. This is very important. If everything moves easily the jack will perform correctly. I use WD-40. There is a reason they refer to this jack as the Widow Maker!
mwoodfin is offline
post #11 of 11 (permalink) Old 12-06-2015, 01:04 PM
this is my high lift bracket
2011blackcummins (12-06-2015)
