Turn signals - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 11-30-2015, 02:51 PM Thread Starter
Turn signals
I'm having troubles with my turn signals on my 93. When I go to put them on they just stay stuck on and don't blink. All bulbs work and flashers still work properly. What else should I check for?
EddieM is offline
post #2 of 6 (permalink) Old 11-30-2015, 05:33 PM
thrashingcows's Avatar
Front turn signals are tied into the front fender lower amber side marker lights...if those are burnt out it can cause that issue.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #3 of 6 (permalink) Old 11-30-2015, 05:54 PM Thread Starter
Those are also good
EddieM is offline
post #4 of 6 (permalink) Old 12-01-2015, 02:56 AM
GatorGuy75's Avatar
Not to hyjack but what if the turn signal dash lights stays lit even when your not using it?
Also Eddie M, my truck had that problem and its turned out to be that my voltage regulator wasn't working therefor my alternator wasn't charging the battery and not having enough juice to blink the blinker (or do anything else for that matter)
1992 SC W250 5 speed flatbed
1993 SC D350, no motor parts truck
Making two trucks into one
GatorGuy75 is offline
post #5 of 6 (permalink) Old 12-01-2015, 11:10 AM
Blue Goose's Avatar
at least in old cars (Chryslers) when a dash turn signal is on, it means there is a burnt out or not working bulb,on the same side as the lit dash light.
Blue Goose is offline
post #6 of 6 (permalink) Old 12-02-2015, 07:51 AM Thread Starter
It's just doesn't blink. When I go to put it on it just stays on no blinking. All bulbs are okay
EddieM is offline
