speedometer problem - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 08-15-2015, 10:53 PM Thread Starter
speedometer problem
I can't get my speedo to work. It is a 91 Dodge 350 w/ Cummins &4 speed auto. I have changed the VSS (twice) and replaced the small gears in the speedo head, even tried a used head borrowed from a friend, no help. I also paid $200 to have the computer repaired. What voltage should I find at the VSS plug? At the head? Anything else I can do?
Rolland
58coupe is offline
post #2 of 9 (permalink) Old 08-15-2015, 11:31 PM
simplysmn
simplysmn's Avatar
iTrader Score: 11 reviews
Did you hook the transfer case side to a drill and see if you have anything ? Trace your wiring down also .After all it's a 20+ yr old truck it could have a bad wire .
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto sxe62/70 turbo 6x13 injector's full 4 in Diamond Eye Exhaust ,366 spring and THD fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #3 of 9 (permalink) Old 08-16-2015, 10:10 AM Thread Starter
I will check the wiring and make sure the VSS is turning. Does anyone know what voltage this system works on? Does the signal feed through the computer?
58coupe is offline
post #4 of 9 (permalink) Old 08-21-2015, 11:51 AM
Grey Wolf's Avatar
This not to say that anyone else will have this problem but when my speedo quit working I had a different fix. The vent tube for my transfer case was very close to the wiring for the VSS it had been laying (or bouncing) on the wires for who knows how long. I cleaned all the oil, dirt, wrapping, etc. off and found there was only one strand of the stranded wire still intact. The fix, cut the wire put in a connector and back in business. Oh and relocate the vent tube line!
'93 LE W250 5spd 3.54 White Reg Cab
350,000 Miles.
'06 2500 SLT SRW Quad Cab 4X4, G56, Big Horn edition.
Grey Wolf is offline
post #5 of 9 (permalink) Old 08-21-2015, 12:07 PM
justinfonder's Avatar
is the truck a 4x4 first off? if so, make sure the ratio adapter on the transfer case isn't bad. take it off, turn one side by hand, other side should turn as well.
pull the gear drive out of the t-case and make sure it's not chewed up. you have 3 things to check at the t-case, gear drive, ratio adapter, and VSS.
also, as grey wolf mentioned, check all of your wiring. mine was rubbing on the yoke and had stripped down to a couple strands by the time I found it. wire loom and zip ties are your friend under there.
'67 D100 on '89 D350 chassis/12v/a518 --- '88 Ramcharger on '93 W250 chassis/12v/47rh --- '93 W250 race truktor --- '03 1500 shorty 12v/a518 --- 12 3500 cclb studded, deleted, tunez, 5
justinfonder is offline
post #6 of 9 (permalink) Old 08-23-2015, 08:22 AM
There should be a speed sensor to replace..
branock is offline
post #7 of 9 (permalink) Old 12-01-2015, 05:32 PM
Baxpilley24's Avatar
just bought a shiny w250 this weekend. (will post pictures soon) funny thing happens everytime i drive it. the speedo won't work right away in the morning. But when I am getting closer to work it works just fine.
'93 D250 LE, rebuilt A518, 3:54 rear, 4" dp into 5" Aero-Turbine muffler, m&h m4 pin & 3200gov & spacer '84 Ford F150 4x4, 300 L6 1bbl, 4spd, w/ 400k+ New to me. '92 W250. Lots of boring stock parts
Baxpilley24 is offline
post #8 of 9 (permalink) Old 12-01-2015, 05:45 PM
Looks even better in person!
post #9 of 9 (permalink) Old 12-07-2015, 07:47 PM
fox001's Avatar
My speedo was intermittent in my truck. Everything on the truck was good, the fix was a different speedo from another truck. Hasn't skipped a beat since.
93 W250 Ext cab, early 04 swap (305 hp),5spd getrag, FASS 150, SouthBend, gauges, Smarty,e-fans,4" TBE, AFE CAI, Jacobs brake, Kelderman air bag setup.
fox001 is offline
